Which 722.6 for OM606 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Which 722.6 for OM606 (/showthread.php?tid=3312) |
Which 722.6 for OM606 - kmaser - 01-30-2012 I currently have a OM606a bolted up to a 722.3 4 speed and I want to put a 722.6 5speed behind it using the PCS controller. It's in a g wagen so it needs to bolt up to the engine as well as be able to use the 6 bolt output flange to mate to the CV driveshaft. So the easiest would be to use a G500 transmission, does anybody know if the bellhousing is the same or did the V8 722.6 use a different bolt pattern that the OM606? ![]() Thanks RE: Which 722.6 for OM606 - aaa - 01-30-2012 The 722.6 bellhousings are removable. V8 will be different of course. RE: Which 722.6 for OM606 - DeliveryValve - 01-30-2012 (01-30-2012, 03:37 PM)aaa ... V8 will be different of course. Bellhousing pattern shot of the M113E50. |
