Cummins 12V turbo swap - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Cummins 12V turbo swap (/showthread.php?tid=3361) |
Cummins 12V turbo swap - MERCEDES-BENZ - 02-15-2012 Has any one swaped a 12V cummins turbo which is the Hy35 i believe onto a OM617.952 or will it even work? i was thinking about doing this to a 300SD or twin turboing it using the stock turbo and the Hy35 both set ups would use a intercooler. RE: Cummins 12V turbo swap - aaa - 02-16-2012 http://www.superturbodiesel.com/std/Thread-Jesse-s-hy35-powered-w116 RE: Cummins 12V turbo swap - MERCEDES-BENZ - 02-17-2012 I actually already read that now what about a twin turbo set up? RE: Cummins 12V turbo swap - sassparilla_kid - 02-17-2012 Twin turbo is hard to do since there are 5 cylinders so it doesn't divide up very well, as for sequential/compound turbo setups http://www.superturbodiesel.com/std/Thread-OM617-compound-turbos It seems a little overkill to me, I would rather have a nice vnt setup and call it done lol RE: Cummins 12V turbo swap - dieselboy - 02-17-2012 The hy35 is from a 24v cummins. RE: Cummins 12V turbo swap - MERCEDES-BENZ - 02-17-2012 It is hmm then what is off of a 12V cummins? RE: Cummins 12V turbo swap - diesel2fast4u - 02-17-2012 (02-17-2012, 03:03 AM)MERCEDES-BENZ It is hmm then what is off of a 12V cummins? In the dodge pickup, Early 12V with rotary pump H1C with 18cm hsg no wastegate 12V linepump if I rmember correctly is HX35 with internal wastegate 12cm hsg |
