W123 tachometer - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: W123 tachometer (/showthread.php?tid=3381) |
W123 tachometer - RonB - 02-22-2012 Hi, down here in OZ ,none of our diesels came with a tacho , how do they pick up a signal from the engine? is it a hall effect pickup? Could one from a gas powered car be made to work using the diesel wiring? . RE: W123 tachometer - Simpler=Better - 02-22-2012 There is a hall effect sensor at the crank by the harmonic dampener. It goes to an amplifier, and then the gauge cluster in the car. RE: W123 tachometer - willbhere4u - 02-22-2012 You could probably fab up a pick up sensor and make a converter box to run the gas tach RE: W123 tachometer - RonB - 02-23-2012 Does anyone have a part number for the amplifier and cable? RE: W123 tachometer - Captain America - 02-24-2012 This might help. Adding a Tach RE: W123 tachometer - RonB - 02-24-2012 (02-24-2012, 02:53 AM)Captain America This might help. Hey thanks!! i did a search of the site and never found that thread. It's a pity the W126 tacho will not fit in a W123 cluster because i have a pile of them. I now know how to work a W wire into a alternator and the 6 pulse rule . Even at my age i can learn stuff everyday ..ha ha ha Anyhow, using a W wire i do not need to worry about a tach amplifier ,but i also learned how they are just the diagnostic plug with the amp plugged into it so i'll go the simpler route. |
