Newbie Mercedes 190D - Printable Version
+--- Thread: Newbie Mercedes 190D (/showthread.php?tid=3396)
Newbie Mercedes 190D - Globy - 02-28-2012
Hi to everyone I'm new to this kind of things so take easy on me!Tongue
I'm 22 years old and have a beautiful Mercedes 190D ( post pics later), and love the car, and sometimes my friends tend to joke with meDodgy, they just don't understand!
Well, cuting the talking, I want to ask you Diesel experts and to all of you, what improvements can I do with my humble diesel 4 cylinder, without engine collapse, just a little bit more power if it possible.
I'll wait from you....
Thanks
David
RE: Newbie Mercedes 190D - aaa - 02-28-2012
Slap a turbo on it. Between that and adjusting the pump yourself you should get a little more power.
If you have the cash you can slap an upgraded pump on it too, that would get alot more power.
RE: Newbie Mercedes 190D - tomnik - 02-28-2012
Hi,
get in touch with Carlos from Portugal, don't have his member name right now.
Tom
(02-28-2012, 07:52 AM)Globy Hi to everyone I'm new to this kind of things so take easy on me!Tongue
Thanks
David
RE: Newbie Mercedes 190D - Globy - 02-28-2012
(02-28-2012, 04:27 PM)aaa Slap a turbo on it. Between that and adjusting the pump yourself you should get a little more power.
Thanks,
but I think slaping a turbo it will melt down the pistons? or pretty soon engine failure??what is the expected lifetime?
How can I upgrade the pump?
[quote='tomnik' pid='38979' dateline='1330468257']
Hi,
Tom
[quote='Globy' pid='38951' dateline='1330433564']
Thanks,
could you give me something more? It is a little bit dificult just with name Carlos.....
"cjcosta" is the member name here.
Tom
RE: Newbie Mercedes 190D - yankneck696 - 02-28-2012
Putting a turbo actually can prolong the life of the engine due to pumping more air & making a leaner ratio, that lowers the EGT (Exhaust Gas Temp)... It will also clear up any black smoke (un burnt fuel). A small turbo & up to 10 PSI boost combined with tweaking the IP will give you some good power & still give good longevity to the engine.
Ed
RE: Newbie Mercedes 190D - Globy - 02-29-2012
(02-28-2012, 09:39 PM)yankneck696 Putting a turbo actually can prolong the life of the engine due to pumping more air & making a leaner ratio, that lowers the EGT (Exhaust Gas Temp)... It will also clear up any black smoke (un burnt fuel). A small turbo & up to 10 PSI boost combined with tweaking the IP will give you some good power & still give good longevity to the engine.
Ed
Could you explain a little better as I'm not following.
Because since we are getting more air/fuel meaning more power then we reaise the temperature??Am I wrong?
Thanks
(02-28-2012, 06:59 PM)tomnik "cjcosta" is the member name here.
Tom
Thanks already talked to him.
RE: Newbie Mercedes 190D - willbhere4u - 02-29-2012
Adding air to a diesel lowers the temps by leaning it out / adding fuel raise the temps if you keep it under 10psi and tweak the stock injection pump it should not get any hotter than with out a turbo
RE: Newbie Mercedes 190D - Globy - 03-02-2012
Thanks,
How can I tune my pump, before installing a turbo? any DIY?
RE: Newbie Mercedes 190D - Globy - 03-03-2012
Any advise or tip?? Tongue
RE: Newbie Mercedes 190D - bad3gakk - 03-03-2012
http://www.superturbodiesel.com/std/Thread-IP-Full-Load-Adjustment-Procedure-for-the-MW-and-M-pumps
(03-03-2012, 04:39 PM)bad3gakk http://www.superturbodiesel.com/std/Thread-IP-Full-Load-Adjustment-Procedure-for-the-MW-and-M-pumps
Thanks, I didn't Know that the 190D/250D/300D were identical.
RE: Newbie Mercedes 190D - Alastair E - 03-03-2012
Well--The basic engine series is the same between 190D/250D/300D, but there are many differences!
(03-03-2012, 06:56 PM)Alastair E Well--The basic engine series is the same between 190D/250D/300D, but there are many differences!
I mean the pump
RE: Newbie Mercedes 190D - Globy - 03-11-2012
So as I said, some pictures now!
[Image: img0041dl.jpg]
[Image: img0043nz.jpg]
[Image: img0040aqv.jpg]
[Image: img0042ym.jpg]
This is my lovely baby!TongueTongue
RE: Newbie Mercedes 190D - barrote - 03-11-2012
hy there,
tb sou de lisboa, qualquer duvida sobre esse tuning grita!
the best u can do is finding a 602 td engine and from that on u can go racing to your friends as well belive me they will be amazed "with tractor fuel" power hehe.
but with this 601 engine that´s not much u can do they tend to be weak, but anyway as other members write above turbo it and u can get 100hp without to much damage expected.
In my case i have one 124 with 605 engine and i´m pursuing 300hp.
regards
RE: Newbie Mercedes 190D - sassparilla_kid - 03-15-2012
That is one clean mercedes, looks like it just rooled off the showroom floor!!
