Towing an '83 300SD? - Printable Version
+--- Thread: Towing an '83 300SD? (/showthread.php?tid=34)
Towing an '83 300SD? - Lapoint - 11-06-2008
Will I damage the transmission if I tow it two blocks, in neutral, with the rear wheels on the ground? I doubt I will exceed 20mph while towing.
Re: Towing an '83 300SD? - winmutt - 11-06-2008
Lapoint Will I damage the transmission if I tow it two blocks, in neutral, with the rear wheels on the ground? I doubt I will exceed 20mph while towing.
Probably not. Go slow.
Re: Towing an '83 300SD? - ForcedInduction - 11-07-2008
75 miles at up to 30mph is the limit for flat towing an automatic. So spoketh my owners manual.
Re: Towing an '83 300SD? - w108om617 - 11-14-2008
hello be safe if you move a car automatic gear box whithout any engine working
be safe remove the rubber part between transmission and rear differential to be ok on the road
