mercedes 240d 617 +4spd conversion - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: mercedes 240d 617 +4spd conversion (/showthread.php?tid=341) |
mercedes 240d 617 +4spd conversion - willbhere4u - 04-30-2009 i just picked up a 1980 240d for 500 turns out it was auto so i have a 4spd and shift linkage and a great 617 turbo with k 26 turbo but want to put both in my 240d auto i need to find a pedal set and flywheel do i need the cross member form that car as well? http://www.youtube.com/watch?v=sqdexqX0bhM thanks william 1980 240d auto 1980 300sd parts car 1958 219 ponton project car RE: mercedes 240d 617 +4spd conversion - winmutt - 04-30-2009 You have the right xmember with from the auto 240d. The DS will need shortening. RE: mercedes 240d 617 +4spd conversion - kamel - 04-30-2009 I'm in the process of doing my 4spd 617 as we speak. Pictorial will be up shortly. ![]() RE: mercedes 240d 617 +4spd conversion - willbhere4u - 05-04-2009 thanks that would be great!!! I'm dying to do this swap I went junkyarding this weekend but was unsuccessful in finding a good w123 parts car all I got was a back window I'll keep looking for a peddle set I think I found a fly wheel from a 1969 220d will that work on a 617turbo ![]() RE: mercedes 240d 617 +4spd conversion - Section106 - 05-04-2009 Which 240D model years can be used to bolt onto a 617? I found a 76 240D manual. Will that work or should I try to find something from the 80s? RE: mercedes 240d 617 +4spd conversion - ForcedInduction - 05-05-2009 Any 220D or 240D will work. RE: mercedes 240d 617 +4spd conversion - JB3 - 05-05-2009 A 300d automatic trans mount will also work on the 240. Dont know if the SD mount is the same, but if your reversed the plate, the bolt holes line up. I did mine as a temporary solution, and left it on for about 6 thousand miles without issue. RE: mercedes 240d 617 +4spd conversion - ForcedInduction - 05-05-2009 It won't stay that way for long. The 240D automatic crossmember is the same as the manual 300D. RE: mercedes 240d 617 +4spd conversion - willbhere4u - 05-11-2009 thanks for all of the help!!! the peddle set and clutch master are all I have left to find still! going to try a different yard next weekend is the 220d flywheel different weight than a 240d? just curious RE: mercedes 240d 617 +4spd conversion - willbhere4u - 06-08-2009 so I found a peddle set and a trans with 32k miles what else do I need for the om 617 vrs om616? do I need a different radiator oil cooler? any thing else???? so far I have a shift assemble, peddle set, trans, master and slave cylinder and lines RE: mercedes 240d 617 +4spd conversion - winmutt - 06-08-2009 The shifter linkage and DS will have to be modified for fit. I would get the DS done first. You also need a flywheel and clutch. I just happen to have a set for sale. RE: mercedes 240d 617 +4spd conversion - willbhere4u - 06-13-2009 I just bought a clutch kit and got a fly wheel from a 220d sorry. I'm pulling the 617 out of my w116 in the next couple of week ends hopefully ! I got the peddle set installed alreaty it fit nice. |
