OM603 injector pump - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: OM603 injector pump (/showthread.php?tid=3410) |
OM603 injector pump - JustPassinThru - 03-01-2012 It's in a local yard, on a 1986 300SDL. Bosch # 0 400 076 992 Mercedes # 603 070 10 01 ER 0008 I didn't write down the PESC number. It has 6mm elements. They'll sell it to me for $100. The smaller thingy behind it, with all the throttle linkage, is already gone. PM me if interested. But don't wait long. RE: OM603 injector pump - led-panzer - 03-01-2012 Only has 5.5 mm elements. If you had the PES number it would be PESCM55... The 55 meaning 5.5 mm elements. The only pumps with 6 mm elements are the turbo 606 and 605 pumps RE: OM603 injector pump - JustPassinThru - 03-02-2012 No, it starts PESCM6. 6mm elements. I'm quite sure of that. It was unusual so it caught my eye. It is very clean and has non-standard nuts holding it on, so it is not original. Looks almost new. First $300 takes. RE: OM603 injector pump - 2996 - 03-02-2012 Just to give people a heads up, the seller is asking $300. RE: OM603 injector pump - JustPassinThru - 03-02-2012 Not worth my time, fuel, and labor to pull it for less. Speak now or forever hold your piece, the car is slated to be crushed tomorrow. |
