Changed the subframe bushings but.. - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: Changed the subframe bushings but.. (/showthread.php?tid=3458) |
Changed the subframe bushings but.. - Purplecomputer - 03-18-2012 but.. they wont go all the way in. I tightened the big bolt which kinda looks like an AK47 bullet all the way in and its tight as can be but the bushings stick out a little. Do I NEED to make sure they are properly in place or will they just sink in? btw, the rear end is very tight now RE: Changed the subframe bushings but.. - Purplecomputer - 03-19-2012 no one has any input? Maybe ill post some pictures later tonight RE: Changed the subframe bushings but.. - serverman777 - 03-19-2012 " the rear end is very tight now" haha I like the sound of that. RE: Changed the subframe bushings but.. - sassparilla_kid - 03-19-2012 (03-19-2012, 09:12 PM)serverman777 " the rear end is very tight now" haha I like the sound of that. lol RE: Changed the subframe bushings but.. - Simpler=Better - 03-20-2012 Were the new bushings significantly smaller than the old ones? Did you oil the threads or anything? When I pulled mine it al went back together no problem RE: Changed the subframe bushings but.. - Purplecomputer - 03-20-2012 (03-20-2012, 05:57 AM)Simpler=Better Were the new bushings significantly smaller than the old ones? Did you oil the threads or anything? When I pulled mine it al went back together no problem The new bushings are a very tight squeze. Almost to the point were i would need to have some sort of tool to press them in i cant push them in with my hands. Also i never removed the subframe to do this job. |
