Turbo rods on N/A crank? - Printable Version
+--- Thread: Turbo rods on N/A crank? (/showthread.php?tid=3495)
Turbo rods on N/A crank? - bad3gakk - 04-02-2012
Would 606 turbodiesel rods fit an 605 N/A crank?
Since the 606 and 605 turbodiesels share pistons and rods, you could interchange there.. but i dont know if the crank bearings are the same size...
RE: Turbo rods on N/A crank? - hansendk - 04-02-2012
the crankshaft is the same std. size 47.950-47.965 mm.
but the bearings are not, turbo`s are sputter type
you cant take the conrod from a turbo and use n/a pistons the piston pins are not the same size.
