Can ALDA be added to NA pump - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Can ALDA be added to NA pump (/showthread.php?tid=3556) |
Can ALDA be added to NA pump - TurboWalt - 04-16-2012 Can ALDA be added to a NA M pump? I don't think it can, but admit my pump knowledge is limited. I'm having a hard time finding a core Turbo M pump to send to Goran for my OM602 Turbo. RE: Can ALDA be added to NA pump - willbhere4u - 04-16-2012 You can remove the A.D.A form a non turbo pump and replace it with a factory ALDA although I believe myna in Sweden builds custom external ALDA's RE: Can ALDA be added to NA pump - aaa - 04-16-2012 If you are sending it to be modded, then I would not worry as much about finding a turbo pump. The differences can be adjusted away when the pump gets opened. RE: Can ALDA be added to NA pump - TurboWalt - 04-19-2012 I've been informed that ALDA can be added to an ADA pump. Of course the parts are expensive. RE: Can ALDA be added to NA pump - pp d - 04-19-2012 (04-19-2012, 01:42 AM)TurboWalt I've been informed that ALDA can be added to an ADA pump. Of course the parts are expensive. Cheaper and simple solution is pneumatic cylinder RE: Can ALDA be added to NA pump - TurboWalt - 04-19-2012 (04-19-2012, 08:24 AM)pp d(04-19-2012, 01:42 AM)TurboWalt I've been informed that ALDA can be added to an ADA pump. Of course the parts are expensive. Can you explain further and post a pic of using pneumatic cylinder vs ALDA? RE: Can ALDA be added to NA pump - aaa - 04-19-2012 Finding a used alda shouldn't be hard or expensive. RE: Can ALDA be added to NA pump - jeemu - 04-20-2012 (04-16-2012, 03:55 PM)willbhere4u myna in Sweden builds custom external ALDA'sIf you mean Myna-Diesel? Its not Sweden, it s in Finland |
