IP seal - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: IP seal (/showthread.php?tid=3558) |
IP seal - Druk - 04-17-2012 I'm sure there should be an O-ring or gasket between the IP and the timing cover on a 606-962 engine but can find nothing on the EPC. I'm also sure I've read it on here somewhere but a search produces nothing. Any ideas please? Also, is a new LH bolt recommened for the timing wheel on the pump? Thanks. Derek. RE: IP seal - plurkje - 04-17-2012 The pump has a o-ring, should be A012 997 83 48, it's one of the attachment parts. Even without EPC I could find the number within minutes. The bolt is reuseable. good luck RE: IP seal - Druk - 04-17-2012 (04-17-2012, 11:50 AM)plurkje The pump has a o-ring, should be A012 997 83 48, it's one of the attachment parts. Even without EPC I could find the number within minutes. The bolt is reuseable. Excellent. Many thanks. ![]() |
