Rear hydraulic system - Printable Version
+--- Thread: Rear hydraulic system (/showthread.php?tid=3559)
Rear hydraulic system - Robert_UAH - 04-17-2012
What is required to convert from the rear hydraulic suspension on a W123?
RE: Rear hydraulic system - Simpler=Better - 04-17-2012
You will need to weld in some kind of spring perches. I don't know if the SLS has springs or not from the factory
RE: Rear hydraulic system - aaa - 04-17-2012
You need replacement springs and shocks. The stock springs will sag without the hydraulics supporting them.
http://slsconversion.com/
RE: Rear hydraulic system - Robert_UAH - 04-19-2012
So I just need some springs and Bilstein HD shocks. No need for different spring perches or anything?
RE: Rear hydraulic system - propigskinSLS - 06-05-2012
(04-19-2012, 08:58 AM)Robert_UAH So I just need some springs and Bilstein HD shocks. No need for different spring perches or anything?
No spring purch change or modifications required:
You can order my springs at www.slsconversion.com
I also sell stock type shocks that bolt right in and a sls pump block off plate.
You can use Bilstein shocks also off a w123 300D sedan that bolt right in if you want the best shocks....
Thanks,
Erik
