A rod in my rear view mirror... - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: A rod in my rear view mirror... (/showthread.php?tid=3641) |
A rod in my rear view mirror... - bad3gakk - 05-14-2012 My brand new 8mm pump, had gotten a harsh ride from finland, and the original alda had to be fiddled with to get the throttle to move... no biggie i thought... Yesterday, finished mounting, i took a test drive.. the clamps wouldnt hold 2,5 bars of pressure and it blew off.. aaah whattahell, i thought and took the 3 hour drive home... Everything sounded and felt good.. Came from wrk 2day, fixed the plumbing and took a drive... another hose blew off, but this time, it sounded like the timing in the pump had retracted/progressed... It idled nasty/&hard.. I didnt think it was that bad, since it didnt knack when i gave it 1/3 throttle.... On my way home, BANG... The fourth cylinder threw a fucking rod out Right behind the injection pump... How? What happened? RE: A rod in my rear view mirror... - George3soccer - 05-14-2012 Ouch would love to hear how the hell that happened. RE: A rod in my rear view mirror... - tomnik - 05-15-2012 Hi, when inserting the pump shaft into the timing device did it go in all the way until the pump got to the block and then could you move the timing device a bit back and forth on the shaft? I think: the spline on the shaft was not correctly in the timing device, you pulled the pump in using the screw (timing device/shaft). I did this once and damaged the spline which then does not hold the torque and snaps, mine came when decelerating/lifting my foot after acceleration. Horrible nailing at idle, then I checked the timing which was way out. When I removed the pump I had to use a punch to get it out of the timing device. The spline in the timing device was damaged. I bet this also happened here, the rod is then a result. You will remember these words when you take out the pump.... Tom (05-14-2012, 04:14 PM)bad3gakk My brand new 8mm pump, had gotten a harsh ride from finland, and the original alda had to be fiddled with to get the throttle to move... no biggie i thought... RE: A rod in my rear view mirror... - bad3gakk - 05-16-2012 I didnt time the pump myself... But I suspect this to have happened... Another theory, is it was "drowned" in diesel, the moment the intake pressure dropped, due to the failure of my clamps on the plumbing between my intercooler and intake manifold... The combustion chamber might have contained so much diesel, so the piston couldnt compress entirely, and the rod bendt and eventually died... RE: A rod in my rear view mirror... - winmutt - 05-16-2012 (05-16-2012, 06:43 PM)bad3gakk I didnt time the pump myself... But I suspect this to have happened... Certainly could be. Who built your pump? RE: A rod in my rear view mirror... - erling66 - 05-18-2012 (05-16-2012, 06:43 PM)bad3gakk I didnt time the pump myself... But I suspect this to have happened...I don't think that is possible. Even with your BIG pump, you would not be able to inject enough fuel to fuel lock the engine, no matter how much air you gave it(and in your case, didn't give it) I agree with Tom or it was just a coincidence, the rod was bad and couldn't handle your sodomizing RE: A rod in my rear view mirror... - Simpler=Better - 05-18-2012 Will his pump fit a 617 ? ? RE: A rod in my rear view mirror... - MFSuper90 - 05-18-2012 Don't feel too bad. I got a wrecked 79 300D for parts and got it running, the guy said it probably ran out of oil when he wrecked it, but i thought id try it anyhow. Ran decent for a couple minutes, sounded like it was gonna lock up, so i floored it. Threw a rod where the motor mount bolts on, broke the motor mount into two pieces, it was fun RE: A rod in my rear view mirror... - bad3gakk - 05-20-2012 Herlevis tractor pulling buildt the pump... 8mm elements, and rebuildt governor weights for max fuel to 7300rpm.. And does not fit a 617.. It probably didnt lock.. But it ignited LONG before it should, because the combustion chambers contains unburned fuel from the last injection sequence... This i think will be a wery unlucky situation for the engine, then revving over 6000rpm :p RE: A rod in my rear view mirror... - EDH_Performance - 05-21-2012 (05-20-2012, 09:15 AM)bad3gakk Herlevis tractor pulling buildt the pump... 8mm elements, and rebuildt governor weights for max fuel to 7300rpm.. Have you stronger valvesprings? Mine had valvefloat at 6200rpm, and ruin the engine! RE: A rod in my rear view mirror... - bad3gakk - 05-21-2012 eehh.. ups? I'm pulling the cylinderhead off when i get some time off, to measure and probably replace them... Any ideas of where i can get a hold of some tougher ones? Maybe a set of extra ones to fit inside the ones thats already there? RE: A rod in my rear view mirror... - EDH_Performance - 05-21-2012 (05-21-2012, 04:02 AM)bad3gakk eehh.. ups? I'm pulling the cylinderhead off when i get some time off, to measure and probably replace them... Any ideas of where i can get a hold of some tougher ones? Maybe a set of extra ones to fit inside the ones thats already there? I will probably recomend you to take a chillpill before you do that If you have had valvefloat on the om606 engine, you will get a nasty suprise I have a dialog with a Norwegian company that are making some springs for this engine, so i can send you a PM when they are finnished RE: A rod in my rear view mirror... - Alastair E - 05-21-2012 (05-20-2012, 09:15 AM)bad3gakk Herlevis tractor pulling buildt the pump... 8mm elements, and rebuildt governor weights for max fuel to 7300rpm.. Personally, I would say that as the pump will allow the engine to run Well over its designed Max Revs, then a rod-bolt failed and the rest you know.... Rod bolt failed due to the extreme stretching as the piston passes over TDC (At this point--The piston wants to keep Going Up due to Inertia, and the crank wants to pull the piston back Down again!) --- because it was being run Too Fast for Those Bolts/Studs.... Diesel Pistons are Much Heavier than gasser pistons, so generally the revs are limited at a lower level To Prevent the Rod-Bolts/Nuts/Studs from just snapping/stripping due to the higher stretching forces at high revs as the pistons go over TDC.... RE: A rod in my rear view mirror... - willbhere4u - 05-21-2012 In a gas engine the explosion starts before TDC to help the piston change direction RE: A rod in my rear view mirror... - erling66 - 05-21-2012 (05-21-2012, 02:10 PM)willbhere4u In a gas engine the explosion starts before TDC to help the piston change direction Remember these are 4 stroke engines so the explosion only helps every second time the piston turns at top. RE: A rod in my rear view mirror... - bad3gakk - 05-21-2012 (05-21-2012, 04:32 AM)EDH_Performance(05-21-2012, 04:02 AM)bad3gakk eehh.. ups? I'm pulling the cylinderhead off when i get some time off, to measure and probably replace them... Any ideas of where i can get a hold of some tougher ones? Maybe a set of extra ones to fit inside the ones thats already there? I wount touch this engine.. I have a spare one with some failed crank bearings, ill replace the crank, bearings, pistons and rods, and use this... Ill be waiting to hear from you about the springs The bolts in the piston and rod is fine... the rod itself is not... Heaps of folks have been revving the merc DOCH diesels past 7000rpm for a long time, it doesnt seem to break them, but if everything else isnt 100%....its probably just a matter of time.. RE: A rod in my rear view mirror... - dieselmerc - 05-22-2012 i think that problably due to much knocking the pump where "changed" to alot of preegnition and it ignited to early and the rod bend, remember to have a GOOD performance oil and change very ofthen( it is now a high performance engine and not an old tired diesel) and the soot dripps down to the oil pan and mess upp the engine oil so maximum 1000km per oil change do i recommend |
