Modifying the OM617 300SD.. - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Modifying the OM617 300SD.. (/showthread.php?tid=3692) |
Modifying the OM617 300SD.. - forcefed44 - 05-29-2012 First off: I know this topic has been beat to death over the years and I have read up alot of the tech specs but here are my .02s. My '84 300SD is up for a turbo replacement (seriously excessive play) and at this time I will do the intake manifold install for intercooler modification as well as a Garrett T3 hybrid turbo with Spec adjustable 18psi Internal WG. (Currently she's running an Alda deleted stock injector pump, CAI, side exhaust).. I have an "M" pump from a parted 300D euro car. My Question is: Will this add any type of HP/fueling gains left alone (stock "M" pump? Is it worth the effort? I know the stock injector pump has a rack limiter which needs to be removed (so I'm told) to get more fueling and gains but I have heard and read of bad situations with adjusting the internals). I have been told with the M pump, it doesn't have a rack limiter, and I have heard of element replacement to 7.5mm??; but there is no one who will modify these things in the Tri state (NY,NJ,CT) that I have found and I'm not willing to send it overseas.. What about Bosio 265 nozzles? +/-? I just don't want to stick the new turbo and not gain a thing.. I know the OM617 is limited to power modifications without some serious dosh. I'm not expecting 300hp but since she needs repairs already. I would like to modifiy it accoringly. Post of PM me.. Anyone's information could greatly help me here. RE: Modifying the OM617 300SD.. - Captain America - 05-29-2012 Read the sticky on adjusting the MW injection pump. http://www.superturbodiesel.com/std/thread-189.html Removing the rack limiter is the wrong thing to do. You can get a additional fuel without much problem. How power will it support? Dont think anyone has dynoed one recently... |
