OM 662 Tuning - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM 662 Tuning (/showthread.php?tid=3752) |
OM 662 Tuning - Blud - 06-25-2012 Good day. I have got Korean Ssang Yong Musso 2006 with OM 662 2.9 Turbo engine. As I understand it as copy of OM 602 engine. Turbo is GARRET TB 25, injection pump is standard M pump Now it have 125 HP. So, how can I take 200-250 HP from it? 1. I need to replace pump elements to OM 606 6 mm elements. Could you give OEM code of it? 2. Need I change the turbo charger to more effective? Sorry for bad English guys. It's not native. RE: OM 662 Tuning - stig - 06-27-2012 I think you should ask these guys! http://www.youtube.com/watch?v=tpj8AkwckBo I have a 662 fitted in my G, great engine. I think the easiest answer to more power is simply a bigger turbo (the standard is pretty small), and some induction work, i.e., better intercooler/plumbing, and give it some more diesel. Let us know. Cheers RE: OM 662 Tuning - devton - 06-30-2012 (06-25-2012, 03:52 PM)Blud Good day. Hí, Yes you can but, have to change the Turbo, intercooler, IP, clutch, i suggest the exhaust manifold too. I think the 6mm element will low. Better the 7,5, and cheaper, if i have right I have same engine, (aftermarket turbo) it could about this power. |
