om606 N/A - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: om606 N/A (/showthread.php?tid=3761) |
om606 N/A - serverman777 - 06-28-2012 I know this info is out there. Making a N/A 606 into a Turbo 606. Someone throw me a link or something. RE: om606 N/A - aaa - 06-28-2012 Only major hiccup I can think of is the exhaust manifold. For turbo oil supply you usually just tee with the oil pressure sensor. RE: om606 N/A - serverman777 - 06-28-2012 Pistons? Rods? Im going to have a custom manifold made. RE: om606 N/A - aaa - 06-28-2012 Rods are weaker, but are you going to superturbo it? RE: om606 N/A - serverman777 - 06-28-2012 Super and turbo? The plan at this time is just a turbo RE: om606 N/A - Simpler=Better - 06-28-2012 (As least to me) 'superturbo' means you're going to feed it rediculous amounts of boost & fuel-well over double the stock amount. RE: om606 N/A - serverman777 - 06-28-2012 Thats the plan. I thought you guys was talking about superchanging+ turbo. Its going into my 201. RE: om606 N/A - aaa - 06-28-2012 Probably should get a stock turbo then. RE: om606 N/A - led-panzer - 06-28-2012 You realize building a "superturbo" costs at least a few grand right? RE: om606 N/A - serverman777 - 06-28-2012 I got the motor and the car.. A pic-apart turbo and A a freebie 603 ip. Weld up a manfold. Pair it with my stock 722.400 tranny. |
