W123 turbo diesel advice - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: W123 turbo diesel advice (/showthread.php?tid=3833) |
W123 turbo diesel advice - 77Merc - 08-06-2012 I've been reading and reading and a lot of numbers are swirling around in my head. I haven't found complete info on some of the swaps I'm entertaining. I've got a W123 240D and want to swap it over to a turbo diesel. I would like a power plant that will make the car quick but I'm not racing it or anything. Just a nice reliable daily driver that can keep up with today's traffic and let me pass grandmas--without a going down hill with a tailwind. I'll be getting a donor car. My 240D also needs a tranny and rearend so if I can get the donor car's tranny and rearend to fit, that's a bonus. Fab skills are plenty. I'm no stranger to metal working and have a welder, plasma cutter, etc and have made cross members, suspension, roll cages, things like that. I like that an OM617 would just about be a plug and play. I'd prefer to go that route if I can, but it's more important that I can get the type of performance I'm looking for. I'm concerned about tweaking it to the hp range I think I need. From what I gather, it would take a lot of expensive mods to bump it past 140hp? Admittedly, I've never been in a w123 that wasn't a 240D so I don't know how well the turbo diesels perform. Perhaps getting to 140hp would suit, I'm not sure. Of course, the OM606 would be badass. I've heard it's a bit of an electrical nightmare to swap into a W123 and there's an issue with clearing an intercooler. From the info I've found, I can't determine if this is an issue for someone who doesn't have fab skills or if there is simply a lack of space. Also, I'm not able to find concrete info on what tranny I'd need to run? Will the tranny from the donor car with an OM606 go into a W123? And then there is the OM603 which, as I understand, has less electronics? I'm worried about the connecting rod issue and don't know how to tell if it's been resolved on a particular block. Any kind of clarification/links/tips/advice is appreciated. RE: W123 turbo diesel advice - Simpler=Better - 08-06-2012 Go with the 617. You're going to be making roughly double the horsepower of the 616 and it's only a little bit heavier. I had my 617 running at around 120hp (by guesstimating, I never dynoed it) and it was plenty quick, even if the auto transmission was failing. A 140hp 617 with a VNT will be MUCH peppier than a 616. You can mate the 617 to the 616's transmission, from everything I have read you definitely want to keep it a manual if you can. 5 speeds are rare and cost around $1000. From what you're saying about your fab skills, you shouldn't have any trouble putting a 617 with a variable vane into your 240. Plus, the 240 has manual climate controls/ windows and is a lighter chassis. Aluminum wheels, a straight exhaust, lighter SD parts, etc. will also make a noticeable difference in performance. I don't know much about the 606, but I believe you can swap on a non electronic injection pump and you're good to go. The 606 has the starter on the driver's side, so you can't mix and match transmissions from a 616/617 or vice versa. RE: W123 turbo diesel advice - 77Merc - 08-07-2012 (08-06-2012, 12:53 PM)Simpler=Better Go with the 617. You're going to be making roughly double the horsepower of the 616 and it's only a little bit heavier. Thanks! What type of turbo has been the best? Something from a cummins maybe? Now to find a donor car. There have been some iron grips on these W123s around here. ![]() RE: W123 turbo diesel advice - Simpler=Better - 08-07-2012 I ran a GT2056V from a Jiberty CRD. You can adapt a 2256V from a Sprinter, the 2256 is a better choice-it's slightly larger than the Jeep turbo. RE: W123 turbo diesel advice - ronnie - 08-08-2012 Look at this, http://www.peachparts.com/shopforum/diesel-performance-tuning/310196-new-engine-build-616-a.html This is my 240d. Right now I can outrun a stock 300. here is another 240 with a lot of power,more then mine for sure. http://www.superturbodiesel.com/std/thread-2163.html RE: W123 turbo diesel advice - raysorenson - 08-08-2012 The 603's are fun bone stock. The 3.0l 603 from the '87 w124 chassis is reliable, it's the 3.5l 603 with the bad rep. That said, the late 617 with very mild pump tweaks in my GF's (heavier than your car) wagon is pretty fun without the A/C on. Plus the 617 leaves open options for cheap 4 speed manual trans conversions. |
