stiff brakes after new master cyl. - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Brakes (https://www.superturbodiesel.com/std/forumdisplay.php?fid=11) +--- Thread: stiff brakes after new master cyl. (/showthread.php?tid=3926) |
stiff brakes after new master cyl. - nevrenufhp - 09-15-2012 I thought for sure I bled them really well. I've done my fair share of mechanicing. I swapped out my old one because it started bleeding down at a stoplight. Put in the new one after the bench bleed, but the pedal is stiff, and it's as hard to push as my 67 F100 with 4 wheel drums. Should I go back to bleeding the whole thing one more time? This is getting tiresome. RE: stiff brakes after new master cyl. - aaa - 09-15-2012 Replace the seal between the master cylinder and brake booster. Or it could be a bad brake booster. RE: stiff brakes after new master cyl. - nevrenufhp - 09-15-2012 That was my next avenue. If I push on it slowly, it acts a lot better. Thanks kind sirrr |
