Stock 92 300D OM602 project suggestions - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Projects (https://www.superturbodiesel.com/std/forumdisplay.php?fid=14) +--- Thread: Stock 92 300D OM602 project suggestions (/showthread.php?tid=3941) |
Stock 92 300D OM602 project suggestions - Bangaway - 09-22-2012 I've got a stock '92 300D OM602 that I plan to turn into a project car. I'm going to stick with the 602 motor. My goal is 350-400 horsepower with a good power band. Any suggestions for the following: Pump--where to have the work performed, what specs? Transmission--manual? Turbo--Holset or Garrett Cooling system? Do I need some sort of security clearance to do a STD Benz project? RE: Stock 92 300D OM602 project suggestions - TurboWalt - 09-23-2012 i think you'll want to go with a OM606 for that kind of power. RE: Stock 92 300D OM602 project suggestions - aaa - 09-23-2012 For a 602 more like 300hp. IP - there are pump guys on the forum, dieselmeken and pp d. Transmission - up to you. If you want manual then a 5-speed from a w201 would be easiest, you would need to beef up the clutch though. Turbo - whatever you can find at an appropriate size for the hp you want. If you want the widest powerband then you will need a VGT or a compound setup. Cooling - the 87 radiator is bigger, if you have issues then that is a possible upgrade path. |
