om606 camhousing...seal... - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: om606 camhousing...seal... (/showthread.php?tid=4019) |
om606 camhousing...seal... - w210tdt - 10-18-2012 are there any seal between the camhousing and the head on a 606? my engine is leaking oil out in the injector wells,from between the head and camhousing.anyone here who have had this problem before.. RE: om606 camhousing...seal... - 2996 - 10-18-2012 Yes, there are seals as far as I can recall. Just get new seals, or a cam cover seal kit, since you might as well replace all the seals if you take the cover off. RE: om606 camhousing...seal... - w210tdt - 10-18-2012 on my engine the seals are missing, so no wonder why its leaking ![]() btw do you know if the prechambers on these engines are having a ring seal to the head?mine doesn`t.. RE: om606 camhousing...seal... - 2996 - 10-19-2012 That would do it ![]() I am not positive, as I have never removed mine, but I believe it does. A dealer or an EPC check would reveal the answer. |
