605 into Isuzu Trooper - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Projects (https://www.superturbodiesel.com/std/forumdisplay.php?fid=14) +--- Thread: 605 into Isuzu Trooper (/showthread.php?tid=4119) |
605 into Isuzu Trooper - BDTD - 11-26-2012 Hi all, Newbie here from the Emerald Isle. I have a 1998 C-250 Estate that has sadly falled to the dreaded tin worm albeit, after achieving interstellar milage, I also have 1 2004 Isuzu Trooper wich steadfastly refuses to excite me in any way. I was wondering if some of you kind souls could educate me on the possibility of mating the 605 from my slowly dissolving merc with the transmission from the 3.0 Isuzu? Are there any golden rules for such an engine transplant? Many thanks. RE: 605 into Isuzu Trooper - Simpler=Better - 11-26-2012 If you can find the bolt patterns of the 605 online, and the Isuzu transmission bolt pattern you should be able ot mate it with an adapter plate, then adapt the Isuzu flywheel to the Mercedes crank. |
