nv 4500 5spd into 126 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: nv 4500 5spd into 126 (/showthread.php?tid=4125) |
nv 4500 5spd into 126 - lpumb3 - 11-27-2012 has anyone ever attempted this ? i blew the trans on my 126 this past week . i was never a fan of autos , this one was healthy , but was unfortunately "over topped off " before i hit the road . In epic fashion dotty made it to her destination in NC . but now she awaits a trans . so far im looking at 1500 for rebuilt warrantied replacements . but i was looking into swaps and theres a comp that makes an adapter plate for GM manuals . NV4500 5spd eazy peazy ,and there cheap .shouldnt be to hard to rig up a sring loaded clutch cable/pedal . from another benz. has any one ever adapted a manual to 126 , or know of any for that matter around the forums ? thanks all RE: nv 4500 5spd into 126 - ronnie - 11-27-2012 Bit of a heavy truck trans, and 5th gear tends to come loose. RE: nv 4500 5spd into 126 - raysorenson - 11-27-2012 There's also adapters to mate with smaller toyota 5 speeds. RE: nv 4500 5spd into 126 - lpumb3 - 11-28-2012 yes the , gentleman , mentioned this toyota plate as well . a local builder said he could prob set up a muncie. trying to see if i can do it for the same cost as a rebuild . if i remember correctly the merc manuals looked very similar . RE: nv 4500 5spd into 126 - lpumb3 - 11-30-2012 so , as far as i can find . the closest , gears would be a wide ratio, muncie out of an older muscle car. or a gentleman mentioned a borg wagner t10 , but said it doesn't like the revs . so far all in i think it will cost a little bit less to do the manual swap , even including some extra budget for the clutch pedal assembly , in any event this will take some time . RE: nv 4500 5spd into 126 - willbhere4u - 11-30-2012 As for a 4 speed just go with the 240d om616 manual. They are cheap and a direct bolt on to the om617 including clutch and flywheel the hard part is a clutch pedal and drive shaft RE: nv 4500 5spd into 126 - benzguy300 - 11-30-2012 The clutch pedal from a W123 will fit with a minor modification RE: nv 4500 5spd into 126 - lpumb3 - 12-01-2012 thanks guys, i will be looking into the merc 4spds out there , im curious as to the long term durability as i start to build up the 617 .thats why i was thinking the muncie would be cool , they can be built HD and it seems for short money . ill need to get ahold of a parts cars for the pedals ,so if i get a runner for the right money this could all work out for less than a thousand . as far as drive shaft length , i was kinda expecting a custom one . i saw a thread on here about one piece with cv's and a spicer yoke etc. ........ this sucks with the car being a thousand miles away . RE: nv 4500 5spd into 126 - lpumb3 - 12-06-2012 update , secured a om617 attached to a 4spd , as well as the cables linkages etc . for the swap . so no gm tranny going in yet . thrread title is now useless RE: nv 4500 5spd into 126 - lpumb3 - 01-17-2013 (11-30-2012, 10:32 AM)benzguy300 The clutch pedal from a W123 will fit with a minor modification i actually got the entire swap out of a 300td . you mentioned a small modification to fit ? could you elaborate , so i know what ill need to do ahead of time . my biggest issue is the car being in another state so i have to get everything ready ship it down etc . .i have already lined up a drive shaft shop in the area . RE: nv 4500 5spd into 126 - charmalu - 01-18-2013 SirNik84 over on PeachParts added a 4-spd to his 84 300SD. http://www.peachparts.com/shopforum/diesel-discussion/276987-installing-new-engine-manual-transmission-my-sd.html Charlie RE: nv 4500 5spd into 126 - willbhere4u - 01-18-2013 I have an extra w126 manual transmission pedal set but it cost me big money to get it shipped over here from Germany. I also found one locally they are very rare and only offered in the 280se hotel cars not originally sold in the U.S. I am swapping a 6 SPD in to my 1987 300SDL here in Colorado RE: nv 4500 5spd into 126 - lpumb3 - 01-19-2013 Thanks guy , i looked at the thread , ill be reading every page . wbh4u , i saw a 280se ,on cl , not too long ago ! you said you had a pedal set up ? still waiting to find out this minor mod to make mine fit . dod you still have that pedal set ? . wnats gonna make this whacky is the car i got this from was a conversion car . im going to have to do everything i can here , and then get down to nc and get the swap done in a week . im giving my self time to clean the engine lol RE: nv 4500 5spd into 126 - lpumb3 - 01-25-2013 soi read the intire thread , and it seems to pucker out and drift .... ill seek more info but for now its gonna be figure it out . although i did locate a source for the "soft parts" of the trans rebuild , gaskets bearings syncros and bushings i hope none of the teeth are sheered or funky i cant feel any draging or clunks rotating the shafts in any direction in all gears so...... whilei was taking off the pump today and soaking everything with wd i noticed there is some thing juft loose all the way iun side the clutch jingling around in the cavity of the crank . as well as inside the pressure plate around the input. so that explains the little pieces of metal i have found in the bell housing and prob why the car got parked . the sprangs blew up !Q so ill try to source an urgrade , they are out there so. this thing has snow balled , and i could have easily grabbed a used auto and driven down to nc and back up for around 1000$? but at this point im still only 600 deep , so at the end of all this im hoping to be under 1800 hard parts and fab/machining . also cant put a value on all the ifo located through this and other forums , so thanks . RE: nv 4500 5spd into 126 - willbhere4u - 01-25-2013 here is a pic of a factory w123 pedal set LH vs an original w126 RH or check out this thread he made his own out of the original at setup http://www.superturbodiesel.com/std/thread-4280.html RE: nv 4500 5spd into 126 - Druk - 01-25-2013 Not sure if a W123 pedal box will swap directly for a W126 cos the 126 has a bigger brake servo and the bolt centers are different. RE: nv 4500 5spd into 126 - lpumb3 - 01-26-2013 thanks for the pics Wbh4u , you selling that setup ? if not do you think you could make a stencil/overlay of both and post the pics ? mesurements ? it looks like the pedals are longer . that brace bar is interesting , from your experience . i havent yet pulled my old pedals i just have the 123 set up i pulled . il go take another look . iDruk , i did grab the booster and master from the swap car . would this booster/master be enough for the 126s brakes? from what ive seen the calipers between models look the same . so would it be eisier to modify my firewall or the pedal assy? RE: nv 4500 5spd into 126 - willbhere4u - 01-27-2013 I've got 2 w126 manual pedal sets I would sell one for the right offer but I have around $300 invested in them each. check with 5spd617 he made one out of his original w126 auto set mixed with parts from a w123 set check out his thread hear. If I knew it was as easy as what he did I would have saved some money and built my own! http://www.superturbodiesel.com/std/thread-4280.html RE: nv 4500 5spd into 126 - lpumb3 - 01-28-2013 thanks for helping out were all a little broke these days . especially with the temptation a elements and pump work i have the resi from the manual as well so i could just put that on my Bmaster and rock out the modified pedals . although i will eventually NEED the 126 genuin manual set gotta replenish my parts cash . just did some trading . |
