5 speed close ratio manual - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: 5 speed close ratio manual (/showthread.php?tid=4167) |
5 speed close ratio manual - Torkey - 12-10-2012 I'm looking for a close ration manual 5 speed that came in the 190E-2.5. Does anyone know what specific model had the close ration 5 in it? Here is the list of 190E's that might have had this transmission. l4 16V I4 16V AMG p/p l4 16V Evolution (Evo I) I4 16V Evolution II (Evo II) Was the close ration 5 an option or was it standard equipment on a specific model. RE: 5 speed close ratio manual - raysorenson - 12-10-2012 They all had a 1:1 5th so I consider them all close ratio. The trans from the later 2.5 is more likely to have the shorter input shaft for the dual mass flywheel which is undesirable. My trans is from an '87 2.3 16v 190e. First is a little on the tall side for a turbodiesel and 5th, of course, isn't overdrive. There's always a good gear to grab:-) RE: 5 speed close ratio manual - charmalu - 12-14-2012 I pulled one back in 09 out of a 86 190E 2.3 16V with 153K. trans # 717.404 Gear ratio 1st 4:08 2nd 2:52 3rd 1:77 4th 1:26 5th 1:00 R....4:04 They are far and few in between. never seen another. Charlie RE: 5 speed close ratio manual - benzguy300 - 12-14-2012 I'm curious do you still have the transmission Charmalu? RE: 5 speed close ratio manual - 5spd617 - 01-20-2013 (12-14-2012, 09:49 PM)charmalu I pulled one back in 09 out of a 86 190E 2.3 16V with 153K. trans # 717.404 i have a 717.404 if you have any questions RE: 5 speed close ratio manual - charmalu - 01-24-2013 (12-14-2012, 10:06 PM)benzguy300 I'm curious do you still have the transmission Charmalu? Yes I still have it. but as of now not for sale. Look up at the top of the thread in the Transmission Information, I posted several pictures of it. Charlie RE: 5 speed close ratio manual - benzguy300 - 01-25-2013 (01-24-2013, 10:00 PM)charmaluHow about a trade for a 717411 and money(12-14-2012, 10:06 PM)benzguy300 I'm curious do you still have the transmission Charmalu? RE: 5 speed close ratio manual - Druk - 01-25-2013 There's also the Getrag 717.450. This one, from a '93 W124 320TE, is bolted up to a 606.962. ![]() ![]() . |
