Info needed for turbo - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Info needed for turbo (/showthread.php?tid=4207) |
Info needed for turbo - xgroundel - 12-30-2012 Hi, I need an information for the Holset HX40W . I find it's price low and desirable and im wondering is it capable of 450-500 hp for these engines- 603,605 or 606 . And if you can prefer other turbine on that price ![]() RE: Info needed for turbo - MFSuper90 - 12-31-2012 Is it a regular hx40, or the superhx40? Do you know what exhaust housing it has on it? RE: Info needed for turbo - xgroundel - 01-01-2013 http://www.ebay.com/itm/HX40W-SUPER-DRAG-Diesel-Turbo-Charger-Holset-T3-Flange-Hx40-Dodge-RAM-CUMMINS-/140900230253?pt=Motors_Car_Truck_Parts_Accessories&hash=item20ce4ee46d&vxp=mtr This is the t3 flange hx40 And the Holset HX35W what would you say about that ? RE: Info needed for turbo - Alastair E - 01-01-2013 Depends on what 'Trim' the turbo is in....There can be many variations of this... A Turbo intended for a truck will not perform as you may expect if used on the smaller capacity OM.606 etc engine. RE: Info needed for turbo - xgroundel - 01-02-2013 Prefer me some ideas about the turbo that can produce that power on 606.910 engine. Thanks |
