Getrag 717.411 inspection - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Getrag 717.411 inspection (/showthread.php?tid=4278) |
Getrag 717.411 inspection - Joaquin Suave - 01-20-2013 I just bought a Getrag 717.411 from a local junkyard. It was in a 109E 2.3l and was really grimy. I've cleaned it up and about to drain the oil to see if there are any chunks in the oil. Other than that is there any other way to inspect the trans ( like inspection ports)? RE: Getrag 717.411 inspection - Druk - 01-20-2013 Did you take the shift lever and rods with it? I have a 717.412 and a 717.450 here and the levers and rods are completely different. Best to get the lever that goes with the box. RE: Getrag 717.411 inspection - 5spd617 - 01-20-2013 (01-20-2013, 12:39 PM)Joaquin Suave I just bought a Getrag 717.411 from a local junkyard. It was in a 109E 2.3l and was really grimy. I've cleaned it up and about to drain the oil to see if there are any chunks in the oil. what are you going to put it in i put that one in my 300sd RE: Getrag 717.411 inspection - Joaquin Suave - 01-20-2013 Thanks for the replies guys... Druk: I got the whole "shooting match"... Trans, links, shifter, brake and clutch assembly (with clutch master cylinder) for 225 euros. The donor had only 160k miles. the junkyard had no clue of what it was... SCORE ![]() 5spd617: I'm not quite sure. Maybe my 87 300tdt "german pickup truck", or I might mary it to one of my "spare" OM603 motors and put into... Something???? I SURE WOULD LIKE an evaluation process though?!?!?! ![]() RE: Getrag 717.411 inspection - Druk - 01-20-2013 (01-20-2013, 04:58 PM)Joaquin Suave Thanks for the replies guys... Good result. Hope you also took the flywheel?? RE: Getrag 717.411 inspection - Joaquin Suave - 01-20-2013 (01-20-2013, 06:04 PM)Druk(01-20-2013, 04:58 PM)Joaquin Suave Thanks for the replies guys... Here is the "booty" ![]() RE: Getrag 717.411 inspection - aaa - 01-20-2013 Turn the input and output shafts and run it thru the gears by hand. Should spot issues like a seized shaft or bad thrust bearings causing it not stay in gear. Not sure how to test the synchros by hand though. RE: Getrag 717.411 inspection - charmalu - 01-21-2013 If you can find a copy of the Haynes manual for the 190E 1984 - 1988, there is a great section on the 5-spd manual transmission. Shows the complete break down and assembly. Don`t know if it is still available or not. I got my copy at a Swap meet . I some times see them in used book stores. This manual make the one they did for the w123 pretty pathetic. Charlie |
