Elements "Jammed" in Mpump - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Elements "Jammed" in Mpump (/showthread.php?tid=4353) |
Elements "Jammed" in Mpump - lpumb3 - 02-15-2013 so i picked up an m pump , little ways back , and curiosity got to me , so i started pulling off all the covers as i cleaned it up . I noticed that the rack would not move with throttle or emergency stop. i was able to slowly turn the pump when i picked it up . putting my drill on it i could see only one element moving , the other 4 would not move and wer stuck in the compressed position. i loosened the rack/element? retainers . eventually the rack/rod?is now moving freely and will sweep only the one element freely . there is no apparent debris or cracking , and the lifters move freely on all 5 . i do not have the socket to take off the delivery valves so i cannot investigate further . will i just be looking at new elements and a rebuild , or should i look forward to more extensive repairs(cost)? |
