Injection pump timing problem - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Injection pump timing problem (/showthread.php?tid=4402) |
Injection pump timing problem - HaavardPYA - 03-08-2013 Tried to mount my pump today. But when the dot on the inlet camgear is visible from the oilcap hole, TDC is about 7-8 o´clock seen from the front of the engine. Shouldn`t the dot be visible when the engine is at TDC? I`ve got the locking tool in the pump so the engine should be set at 14degrees ATDC, right? I mounted the cylinderhead as described in the manuals. Crank at TDC, dots on camgears towards each other(9 o`clock and 3 o`clock), 6,5mm bolt in camgear etc. I have a mock-up pump in the engine now, so the engine is turnable. Planning on starting the engine on Sunday, so i would be very happy for answers! ![]() Any suggestions on what i`ve done wrong? ![]() Best Regards Håvard RE: Injection pump timing problem - axel606 - 03-08-2013 (03-08-2013, 01:20 PM)HaavardPYA Tried to mount my pump today. But when the dot on the inlet camgear is visible from the oilcap hole, TDC is about 7-8 o´clock seen from the front of the engine. Shouldn`t the dot be visible when the engine is at TDC?please what engine are you doing this with? is it a 606? if so the spot on the inlet cam sprocket should be seen going past and out of sight this means nr.1 is coming up to tdc (o/t) turn engine watching the scale on the cramk until 14 deg after o/t then fit the pump /make sure you mount the pump with the adjuster set a bit retarded as the pump always jumps that way /this allows you plenty of adjustment to advance it to optimise. RE: Injection pump timing problem - HaavardPYA - 03-08-2013 Sorry, its an 606 yes! Aha.. I see. I thought you should see the mark. But thank you very much!! ![]() |
