OM605 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM605 (/showthread.php?tid=4425) |
OM605 - ravenxm - 03-17-2013 Hi here my name is Lev i"n new in diesel world i"m from israel so please HELP))))) made some projects at past in petrol now diesel powed needed i have w201 body with 605engine searchin for optional upgrade for 250 - 300 bhp without opening an engine turbo+methanol+coller+bigger elements THX need youre advises places to buy or order things what problems can i meen etc questions are what turbo should i use where can i take elements to fuel pump what is the boos i can safely drive is water methanol injection needed or not/? etc what caN I DO??? RE: OM605 - Booster - 03-19-2013 Holset hx35 7mm pump elements. With the supporting mods/ exhaust and inlet your good for around 400bhp? Kkd make exhaust manifolds to suit holsets, Pump talk to dieselmeken user on the forum. Auto or manual? If the latter think about a new clutch!! Other people will help you with other details. There is a project around with this set up so have a search! Edit: you will need an intercooler don't NEED meth.... RE: OM605 - TheDon - 03-19-2013 add a nice intercooler as well. Plus a transmission that can handle it. RE: OM605 - Eric78 - 03-20-2013 (03-19-2013, 04:09 AM)Booster Kkd make exhaust manifolds to suit holsets, Got link? I found a website for Kkd motorsport but couldn't find manifolds on the site. How much for one for an OM605? RE: OM605 - Booster - 03-22-2013 (03-20-2013, 01:15 AM)Eric78(03-19-2013, 04:09 AM)Booster Kkd make exhaust manifolds to suit holsets, http://www.kkdmotorsport.com/kauppa.php?t=1270711813&k=1270679050 RE: OM605 - ravenxm - 04-14-2013 (03-22-2013, 10:12 AM)Boostermanifold i weld by myself(03-20-2013, 01:15 AM)Eric78(03-19-2013, 04:09 AM)Booster Kkd make exhaust manifolds to suit holsets, no problems with stainless 316SS Another newbie question protection?? what is the safe boost to drive like that? 28PSI 35 psi? do i need an EGT gauge afr gauge? RE: OM605 - Booster - 04-15-2013 Don't know where boost levels start to break things but people with just forged rods are running 3bar! Egt will give you a good idea how its running! Really want to keep them down! RE: OM605 - ravenxm - 04-15-2013 (04-15-2013, 02:19 AM)Booster Don't know where boost levels start to break things but people with just forged rods are running 3bar! where can i get forget rods?? is there any sites for tuned parts for my engine? RE: OM605 - Eric78 - 04-15-2013 (04-15-2013, 04:26 AM)ravenxmhttp://www.stenparnermotor.se/default.aspx?NodeId=43(04-15-2013, 02:19 AM)Booster Don't know where boost levels start to break things but people with just forged rods are running 3bar! Not sure there to get other parts for them, actually I'm not sure what can be done to the inside of the engine apart from rods, pistons, larger valves, stiffer valve springs & maybe a custom cam grind. I don't know if you can get a stronger crank shaft for them, or even need to. RE: OM605 - EDH_Performance - 04-15-2013 Do not buy these swedish rods, they are super thin in the small end! Don`t like high rpm`s...Try to search for eagle rods ![]() What you really need is stiffer valvesprings and camshafts, stock rods hold pretty good ![]() RE: OM605 - Eric78 - 04-16-2013 (04-15-2013, 06:24 AM)EDH_Performance What you really need is stiffer valvesprings and camshafts, stock rods hold pretty goodCan you recommend a maker/supplier of valve springs suitable for an om60x twin cammer? RE: OM605 - EDH_Performance - 04-16-2013 (04-16-2013, 01:21 AM)Eric78(04-15-2013, 06:24 AM)EDH_Performance What you really need is stiffer valvesprings and camshafts, stock rods hold pretty goodCan you recommend a maker/supplier of valve springs suitable for an om60x twin cammer? Here is one Norwegian one, this is the one i have...Can handle up to 8000rpm and fits with the stock om60x retainer, BUT requires a flat bottomshims ( very easy to make, i just used a plain washer from a nut and bolt shop) http://kmcams.com/product_info.php?cPath=32&products_id=885 Contact information: post@kmcams.com RE: OM605 - ravenxm - 04-16-2013 Damn i dont speak this group of languages)))) TNX Peonle i"ll use google translate an other question i'm ordering 7.5mm 140cc fue l pump what aditional turbo i can use to get 300hp exept HX35 (it's realy hard to find it in israel)> |
