Which speedo for a w201 with a 722.6? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Which speedo for a w201 with a 722.6? (/showthread.php?tid=4439) |
Which speedo for a w201 with a 722.6? - Eric78 - 03-21-2013 The speedometer in the w201 is mechanical, & there is no mechanical speedo drive in a 722.6 so which electronic speedos fit into a w201 instrument cluster? Or which complete electronic instrument clusters fit in a w201 & have similar appearance? RE: Which speedo for a w201 with a 722.6? - Kozuka - 03-22-2013 There was no electronic speedo for the w201 as far as I remember. As far as a solution, I would personally probably just go aftermarket and fab up something like this.. ![]() from PP http://www.peachparts.com/shopforum/diesel-discussion/312801-mechanical-electronic-speedometer-conversion-3.html RE: Which speedo for a w201 with a 722.6? - Eric78 - 03-22-2013 Ok, it appears that some later, larger engined w124s had an electronic speedo, & I know these speedos are the same size & shape as a w201 speedo so I think I might be able to put one of these into my cluster. |
