WTB: Instruement Pod / Cluster to put on A Pillar Molding - Printable Version
+--- Thread: WTB: Instruement Pod / Cluster to put on A Pillar Molding (/showthread.php?tid=4451)
WTB: Instruement Pod / Cluster to put on A Pillar Molding - Greazzer - 03-26-2013
Looking to buy or at least info on where to buy the 3 pod cluster for guages which would mount to the "A" pillar molding. I saw some pictures somewhere on this forum of a set which looked like it was made at the factory in Germany it looked so good.
Anyone have a set ...
RE: WTB: Instruement Pod / Cluster to put on A Pillar Molding - Austincarnut - 03-26-2013
Banks makes then for the trucks, just sayin....
(03-26-2013, 07:29 PM)Greazzer Looking to buy or at least info on where to buy the 3 pod cluster for guages which would mount to the "A" pillar molding. I saw some pictures somewhere on this forum of a set which looked like it was made at the factory in Germany it looked so good.
RE: WTB: Instruement Pod / Cluster to put on A Pillar Molding - Simpler=Better - 03-26-2013
Generic and graft in on there
RE: WTB: Instruement Pod / Cluster to put on A Pillar Molding - sassparilla_kid - 03-26-2013
I vote re-engineer the instrument cluster to take smaller gauges, and then add gauges in there. I bet you could fit several more, especially if you got some combination gauges
RE: WTB: Instruement Pod / Cluster to put on A Pillar Molding - w123love - 03-27-2013
(03-26-2013, 10:39 PM)sassparilla_kid I vote re-engineer the instrument cluster to take smaller gauges, and then add gauges in there. I bet you could fit several more, especially if you got some combination gauges
But...but...
A pillar gauges are so cool Sad
RE: WTB: Instruement Pod / Cluster to put on A Pillar Molding - Austincarnut - 03-27-2013
Cut up the hood, move everything there, haven't you guys seen the zero f*cks given rx7? maaaan.....
(03-27-2013, 09:49 AM)w123love
But...but...
RE: WTB: Instruement Pod / Cluster to put on A Pillar Molding - Greazzer - 03-27-2013
Hey, got a dumb question.
As you can tell, I am learning gauges right now.
Do they sell a gauage that bounces around or goes through a certain number of readings. For example, one gauage which does a "sweep" through a few sensors which would reflect tempertrue X, then Y, and then Z, and back to X, Y, Z ... I am wrapping up my new and improved WVO system, and I want a gauge which monitors 3 temps: The grease right before it hits the lift pump, a temp reading as the WVO sits in my 50 plate HE, and a temp gauage for the coolant right before it enters the HE. I want a 3 gauage pod. I wish I could find the damm picture on this forum or somewhere where someone had one and it looked factory. I want 3 gauages on the A pillar. The 2nd gauage is for the motor oil ... same deal with a sweep of temps for varing sensors. 3rd gauage would be for the coolant. I am on the verge of wrapping up a ton of R&D in my DD. Just need to also pester Led-Panzer about some aluminum work. Between college drama, R&D, wife who has a super long honey do list right now, and the list keeps growing ... poop
RE: WTB: Instruement Pod / Cluster to put on A Pillar Molding - Simpler=Better - 03-27-2013
I know exactly the gauge pod thread you're talking about, the kid just used a generic pillar pod, hair drier, and fiberglass/bondo to make it work.
