W210 Pre facelift panel swap - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Body Mods (https://www.superturbodiesel.com/std/forumdisplay.php?fid=21) +--- Thread: W210 Pre facelift panel swap (/showthread.php?tid=4510) |
W210 Pre facelift panel swap - Pinchers - 04-19-2013 Does anyone know if the front wings and bumper from a facelift W210 can be fitted to a pre facelift chassis. Brackets etc all line up RE: W210 Pre facelift panel swap - TheDon - 04-23-2013 Wow, I just looked at an early W210 and man oh man do they look like crap. I think the US only got the facelift models. But if they are anything like the W124 you should be able to swap out panels. RE: W210 Pre facelift panel swap - Magnus - 04-25-2013 (04-19-2013, 03:37 PM)Pinchers Does anyone know if the front wings and bumper from a facelift W210 can be fitted to a pre facelift chassis. Can be done but it is a bit of work.. hood, grille, headlamps and of course mirrors are also needed. front crossbar/beam/member or what its called is different, at least you need it if you plan to have headlamp washers. the inner front fenders/wings are different ( part of the chassie where the fenders are bolted is lower on facelift) I adapted facelift fenders to fit the older chassie when I did it on my w210, RE: W210 Pre facelift panel swap - Pinchers - 04-27-2013 Thanks for the info Magnus |
