606td trans - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: 606td trans (/showthread.php?tid=4540) |
606td trans - ravenxm - 05-01-2013 now i"m goint to put an om606td to an w201 body question can i use a flywheel from my 102engine with my 5sp manual or i need an trans from 606 engine?with its flywheel? RE: 606td trans - aaa - 05-02-2013 If you're not using the electric pump you can use the 102 flywheel. |
