How do you remove a 606 pump? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: How do you remove a 606 pump? (/showthread.php?tid=4622) |
How do you remove a 606 pump? - Bangaway - 06-02-2013 I've never removed an injection pump, but I need to so I can get it modified. I found some instructions but I would like some imput from others if possible. Instructions: http://www.w124-zone.com/downloads/MB%20CD/W124/w124CD1/Program/Engine/605_606/07.1-8410.pdf 1.) buy special tools--the basket or assempbly cage, and blocking bolt 2.)disconect groung battery line 3.)unbolt noise encapsulation (what is this) 4.)unscrew central securing bolt, left hand threaded 5.) turn crankshaft to 14 degrees plus .5 degrees...TDC...look at instructions--please explain in more detail- 6.) remove chanin tensioner--necessary? 7.) unbolt injection lines at pump 8.)detatch vacuum lines at pump 9.) unnplug plastic coupling microswitch 10.)remove cruise control 11.) ARA? unplug 12.)ELR? unplug 13.)overflow restriction, unscrew? 14.) fuel lines, remove 15.)10/2 and 10/3 bolts 16.) injection pump--counter hold injection timing device--what? 17.) forgot-- first remove intake maniflod Do I have to remove the vacum pump? Is bolt 40/3 behind the vacuum pump? What do you use fo the special notched wrench listed in the insturctions? What are the big things to be aware of? Lots of questions, I know. Add what you can, if possible. I gotta get the pump out! Then back in! Thanks in advance. RE: How do you remove a 606 pump? - aaa - 06-03-2013 Yes, you have to remove the vacuum pump to get to the lefthand threaded bolt. The injection pump locking tool is also very useful: ![]() RE: How do you remove a 606 pump? - Bangaway - 06-03-2013 What does the basket do? Do I "need" it? Or is there a way to go without it. RE: How do you remove a 606 pump? - SWL300SDL - 06-25-2013 (06-03-2013, 10:12 PM)Bangaway What does the basket do? Do I "need" it? Or is there a way to go without it. The basket for the vacuum pump? I ditched mine on my 603 when my pump failed. Most new or rebuilt pumps say to ditch the basket. Not to sure if the 606 needs it but I doubt it does being they are so similar. RE: How do you remove a 606 pump? - Druk - 06-25-2013 (06-03-2013, 10:12 PM)Bangaway What does the basket do? Do I "need" it? Or is there a way to go without it. The basket holds the timing pulley in place when the pump is removed. Without it the pulley drops into the timing case. RE: How do you remove a 606 pump? - maxypriest - 06-25-2013 (06-25-2013, 02:48 AM)Druk(06-03-2013, 10:12 PM)Bangaway What does the basket do? Do I "need" it? Or is there a way to go without it. Where do I get one of these baskets? Merc dealer? Are they expensive?! Max RE: How do you remove a 606 pump? - Druk - 06-25-2013 (06-25-2013, 04:38 AM)maxypriest Where do I get one of these baskets? Merc dealer? Read this thread... http://www.superturbodiesel.com/std/thread-4628-post-52368.html#pid52368 I'll take measurements of mine if you feel you can fabricate one from 1mm steel. Not that complicated. RE: How do you remove a 606 pump? - maxypriest - 06-25-2013 Cripes! And the locking tool too!!! RE: How do you remove a 606 pump? - Simpler=Better - 06-25-2013 I haven't torn into a 606 by hand yet but I'm sure that there must be a way to rig it without using the special tool. Safety wire and coat hangers? RE: How do you remove a 606 pump? - hansebanger77 - 06-25-2013 I swapped Pumps on 606 and 603 without any Special Tool. Only for Timing i use the Mercedes Tool.. RE: How do you remove a 606 pump? - boyt - 06-25-2013 Give me part numbers of tools. And I will see what I can do on price. I get them at cost price to merc dealers RE: How do you remove a 606 pump? - Bangaway - 06-25-2013 I think this is the part number 601 589 05 14 00. In the U.S. dealer prices range from about 150 to 300. I got lucky and bought a used one from a nice guy ![]() RE: How do you remove a 606 pump? - boyt - 06-26-2013 Cost price is 129 plus vat. What a rip off. Lucky I have two already. Plus the pump last cking tool. Plus the pump timimg lights |
