Pressure in injector hole/funnel - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Pressure in injector hole/funnel (/showthread.php?tid=4637) |
Pressure in injector hole/funnel - HaavardPYA - 06-11-2013 After i started my 606 a couple of times. It have started to squirt oil or diesel from the hole/funnel where the injector sits.The diesel that squirts up is just some laying in the funnel from after i bleed my fuellines. But where is the pressure from? Is my head cracked? I think that is weird, as there is no pressure in the water. When i overhauled my engine, i took the injectors out of the prechamber. Could it be that the injector has come loose a litte bit. I doesent feel that it's loose when i try to screw it in with my hands. So, what causes the pressure? The engine runs fine from what i can hear with my ears. RE: Pressure in injector hole/funnel - mantahead - 06-11-2013 your injector washers must be leaking and compression is escaping past. RE: Pressure in injector hole/funnel - HaavardPYA - 06-11-2013 Aah, ofcourse! Well, thats good! I tought i needed to take the cams off and use that prechamber tool again.. |
