HX40 or HX30 on 606 for dayly use? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: HX40 or HX30 on 606 for dayly use? (/showthread.php?tid=4640) |
HX40 or HX30 on 606 for dayly use? - ravenxm - 06-12-2013 question who had this turbo installed on 606 engine> with 7.5 elements on what RPM -+ it start to spool will i have any boost till 2000 rpm?? isnt it too big for dayly drive or prefer HX35 i dont want a turbo to enter at 2500-3000rpm i need it to boost at 1500 already to have a good start at dayly drive RE: HX40 or HX30 on 606 for dayly use? - Duncansport - 06-12-2013 There are a few custom turbine housing for the hX35 and HX40 that have a much smaller housing, the .63 i got for my H1C/HX35 is about a 7cm housing vs the OE 14cm Do some Google searches. RE: HX40 or HX30 on 606 for dayly use? - ravenxm - 06-12-2013 i"m talkin about an stock turbine RE: HX40 or HX30 on 606 for dayly use? - hansebanger77 - 06-12-2013 606 + KKD manifold + Hx40 17cm housing t4 flange =3000rpm spool RE: HX40 or HX30 on 606 for dayly use? - Duncansport - 06-12-2013 (06-12-2013, 10:41 AM)ravenxm i"m talkin about an stock turbineRight, what im saying is buy a Big H1C or a HX35 and get a small exhaust turbine housing. I bought my 7 blade big H1C and a custom (small single scroll) exhaust turbine housing all for $400.00. Im sure you wont have full boost at 1500 but closer to 2200 rpm or so. Just my thoughts... RE: HX40 or HX30 on 606 for dayly use? - ravenxm - 06-13-2013 (06-12-2013, 02:25 PM)Duncansport(06-12-2013, 10:41 AM)ravenxm i"m talkin about an stock turbineRight, what im saying is buy a Big H1C or a HX35 and get a small exhaust turbine housing. I bought my 7 blade big H1C and a custom (small single scroll) exhaust turbine housing all for $400.00. Im sure you wont have full boost at 1500 but closer to 2200 rpm or so. no problem with a bit later full boost i have it till 6000rpm i affraid that with stock HX40 i will not have any boost at all till 2000rpm and it will be a turtle RE: HX40 or HX30 on 606 for dayly use? - EDH_Performance - 06-13-2013 (06-13-2013, 05:08 AM)ravenxm(06-12-2013, 02:25 PM)Duncansport(06-12-2013, 10:41 AM)ravenxm i"m talkin about an stock turbineRight, what im saying is buy a Big H1C or a HX35 and get a small exhaust turbine housing. I bought my 7 blade big H1C and a custom (small single scroll) exhaust turbine housing all for $400.00. Im sure you wont have full boost at 1500 but closer to 2200 rpm or so. Some hx35 and hx40 have the same compressor... Hx40 with 14cm housing is pretty good! Some HY35 has superprofile compressorwheel and 9cm housing as standard ![]() RE: HX40 or HX30 on 606 for dayly use? - MFSuper90 - 06-13-2013 I am with EDH, I think a HY35 would be super quick spool! Maybe put an external gate on it to ensure you have enough wastegate, or go crazy on porting the internal gate ![]() |
