God F***in dammit - 2nd damn head to stuck plug - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: God F***in dammit - 2nd damn head to stuck plug (/showthread.php?tid=4684) |
God F***in dammit - 2nd damn head to stuck plug - fcp - 06-26-2013 I've just trashed the 2nd 606 head I had trying to remove stuck plugs. I know they are cheap over here but this is frigging ridiculous The problem on both occasions has been that it has been impossible to remove the hardened electrodes.. others seem to have been able to lever/ twist them out but that has proved impossible with whatever plugs were fitted to these heads... they just snap off in the plug which makes drilling/ tapping etc very difficult indeed. ![]() RE: God F***in dammit - 2nd damn head to stuck plug - MFSuper90 - 06-26-2013 Hahaha nice title. Do you mean glow plugs? RE: God F***in dammit - 2nd damn head to stuck plug - maxypriest - 06-26-2013 I have only taken one out before on a 606, i used amilsil penetrating fluid over 2 weeks before hand then got her hot before attempting the extraction. Came out easily - Might have been lucky... RE: God F***in dammit - 2nd damn head to stuck plug - boyt - 06-26-2013 Took out hundreds. Hot engine with some sas spray and 95% of the time can get them out. If not we use a company to remove them. Normally leaving the head on. RE: God F***in dammit - 2nd damn head to stuck plug - Simpler=Better - 06-26-2013 There is a writeup on PP, one guy made a hydraulic press that took the place of the injector and pushed the snapped GP out with a hydraulic pressure. RE: God F***in dammit - 2nd damn head to stuck plug - Duncansport - 06-26-2013 We see that from time to time here. I've had to fix other shops/guys mistakes with glow plugs many times. My go to method is to get the engine hot, pull the injector, valve cover, and injector tube. Take the prechamber ring out and get a slide hammer and pull the prechamber out (yes it will destroy the glow plug) Then get the guts out of the broken glow plug and tread it to 8 x 1.25 and use a small slide hammer to yank it out. Then chase the treads and put it back together. If you destroy the treads we Time-Sert it back to the correct size. 2-3 hours and your done. As far as preventing the issue just get the engine hot and use a 3/8 impact gun CARFULLY to get the plugs out with a deep 12mm swivel. The action of a impact gun vs your ratchet is that the gun impacts the plug straight on vs you yanking off to the side with you ratchet while you try to loosen it. Just my $.02 RE: God F***in dammit - 2nd damn head to stuck plug - fcp - 06-26-2013 The problem has been that the heads have been off the engine so no prospect of heating them up (I don't fancy the idea of a brazing torch either ![]() Old story too - it was just at the point where I had *almost* got the last one out and I just rushed it. What is a mystery is why others have found removing electrode easy.. If I had been able to do this I thing I would have drilled/ tapped OK. Anyway, I bought another head 100K M this evening.. good news is that plugs are already out on this one. Does anyone know MB tool # for reamer? RE: God F***in dammit - 2nd damn head to stuck plug - willbhere4u - 06-26-2013 Could put it in the oven when the wife is not looking! heat it up on low RE: God F***in dammit - 2nd damn head to stuck plug - AlanMcR - 06-26-2013 To get the electrode out, clamp it with a medium vice grip, then pry it out with a large pry bar. Much easier in the vehicle though. RE: God F***in dammit - 2nd damn head to stuck plug - Simpler=Better - 06-27-2013 Off the engine? Bite the bullet and pay a machine shop $100 to extract it. Just make sure they know it's a $2,000 head before they start drilling. RE: God F***in dammit - 2nd damn head to stuck plug - DiseaselWeasel - 06-27-2013 http://www.youtube.com/watch?v=ee6sfgIhfT4 - there are better tool sets out there, with guides for drilling etc. for CDI engines p.e. - I could bet there's something available for OM60X engines too. But depending on price and times you need to use it - probably more cost effective to leave it to a professional... after all it's a common std. repair, not something exotic... RE: God F***in dammit - 2nd damn head to stuck plug - fcp - 07-01-2013 (06-27-2013, 07:59 AM)Simpler=Better Off the engine? Bite the bullet and pay a machine shop $100 to extract it. Just make sure they know it's a $2,000 head before they start drilling. Fortunately over here it's a $300 head. Even so, painful to be on the 3rd ![]() RE: God F***in dammit - 2nd damn head to stuck plug - Simpler=Better - 07-01-2013 (07-01-2013, 04:34 AM)fcp(06-27-2013, 07:59 AM)Simpler=Better Off the engine? Bite the bullet and pay a machine shop $100 to extract it. Just make sure they know it's a $2,000 head before they start drilling. I hate you Britains more and more every day RE: God F***in dammit - 2nd damn head to stuck plug - hooblah - 07-01-2013 Lol guess I shouldn't tell you I picked up a fully working w210 with a 606 for £300! RE: God F***in dammit - 2nd damn head to stuck plug - Simpler=Better - 07-01-2013 (07-01-2013, 08:06 AM)hooblah Lol guess I shouldn't tell you I picked up a fully working w210 with a 606 for £300! That's okay, you'll never know the joy of having $100 gas v8s everywhere ![]() http://baltimore.craigslist.org/pts/3826394402.html RE: God F***in dammit - 2nd damn head to stuck plug - fcp - 07-02-2013 (07-01-2013, 09:11 AM)Simpler=Better(07-01-2013, 08:06 AM)hooblah Lol guess I shouldn't tell you I picked up a fully working w210 with a 606 for £300! That's true - we also almost never see 617A here either (I want one for my 300TD estate if anyone has one BTW) RE: God F***in dammit - 2nd damn head to stuck plug - Simpler=Better - 07-02-2013 (07-02-2013, 08:56 AM)fcp(07-01-2013, 09:11 AM)Simpler=Better(07-01-2013, 08:06 AM)hooblah Lol guess I shouldn't tell you I picked up a fully working w210 with a 606 for £300! The 606 really is much better, but I love the loud clack clack clack clack at idle, and the slow whine of a 617a as it takes 6 years spooling ![]() We should setup an exchange program: Complete car with a dry transmission, £330 http://baltimore.craigslist.org/cto/3896619131.html RE: God F***in dammit - 2nd damn head to stuck plug - Mark_M - 07-02-2013 (07-01-2013, 09:11 AM)Simpler=Better(07-01-2013, 08:06 AM)hooblah Lol guess I shouldn't tell you I picked up a fully working w210 with a 606 for £300! Yes but at $9 a uk gallon you can keep them lol. RE: God F***in dammit - 2nd damn head to stuck plug - fcp - 07-06-2013 *Update* - Success I bought a new head which arrived last week, straight and plugs already removed. So this afternoon, I though I didn't have anything to loose by having another go at the old head - what more could go wrong, right? Anyway, after much effort, I managed to grind back the hardened electrode sufficiently, wound an M8 tap into the body of the plug and got a long prybar on it.. amazingly it came out and it looks like there is no damage to threads or much inside of the surface of the shaft. It seems that the hole I drilled didn't wonder as much as I had feared :-) I then got to work on the other plug (with no snapped electrode). What I learned is that you have to be really careful with this; twisting movement is what gets the welded end to break free I found, not 'levering' or 'wiggling' - long nosed mole grip pliers certainly helped too. So I now have 2 OM606 heads (well three if you count original trashed head).. hmm so maybe my W123 300TD should have an upgrade ;-) RE: God F***in dammit - 2nd damn head to stuck plug - Simpler=Better - 07-06-2013 (07-06-2013, 05:57 PM)fcp *Update* - Success yeaaaaaaahhhhhh!!!!! RE: God F***in dammit - 2nd damn head to stuck plug - winmutt - 07-08-2013 There is a thread right now on helicoiling them after you drill them out. |
