Gt4082v - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Gt4082v (/showthread.php?tid=4719) |
Gt4082v - bruno_pinho - 07-11-2013 good A garrett gt4082v works in om605?, Or will be too big!? thank you RE: Gt4082v - Turbo - 07-12-2013 Depended how you tend to use it, by it self it is properly to big, in serie set up with high boost can work, but also depended how much you want to put out of the engine and when you want boost. GT is a quite old one, there is 3 generations after that one, GTA, GTB, GTC and GTD what is the performance and data of the engine it come from? Do you have in- and exduser compressor diameter since a map is very hard to get hold of. ported shroud? Do you have a picture on the VNT mecanism? (07-11-2013, 08:13 AM)bruno_pinho good RE: Gt4082v - offroaddieselhu - 07-12-2013 is it geometric turbo ? |
