What gauges - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: What gauges (/showthread.php?tid=4771) |
What gauges - Palmer - 07-27-2013 Hi guys, Quick question - but when you start to fiddle with a diesel, what things do you need to look out for? Obviousely regarding gauges boost and EGT Maybe things like water temp, oil pressure etc? RE: What gauges - larsalan - 07-27-2013 Some people are doing a pressure sensor in the exhaust too. I would say water temp and oil pressure sound good too. RE: What gauges - MFSuper90 - 07-27-2013 depending on what you drive, shouldn't it have a water and oil pressure in the dash? EGT, boost, and some people are doing drive pressure. Fuel pressure is also an important factor RE: What gauges - Palmer - 07-28-2013 (07-27-2013, 02:25 PM)MFSuper90 depending on what you drive, shouldn't it have a water and oil pressure in the dash? The car is a volvo 940 diesel. It has the Vw 2.4 straight six D24tic engine No oil pressure as standard. Has a temp for water but intermittent. Chris |
