Project Andy-Rice - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Projects (https://www.superturbodiesel.com/std/forumdisplay.php?fid=14) +--- Thread: Project Andy-Rice (/showthread.php?tid=4883) |
Project Andy-Rice - EmJay - 09-07-2013 I mentioned in another thread that I had a 2.3-16, so I thought that I would share it. For now the plan is to bring it back to it's glory. It was very rough when I first got it, the only thing good about it really was the motor was strong and the body was straight. ![]() ![]() Replaced headlights with euros ![]() Replaced cracked ass dash and cruddy steering wheel with a donor from a 1990 190 2.6 ![]() ![]() Repaired rat chewed wires (still don't know what system this was from originally) ![]() ![]() Repainted grille and replaced hood star ![]() ![]() Repaired SLS system ![]() fabricated a cup holder ![]() Replaced leaking vacuum lines (too many were replaced, no photos) Replaced fuse box. From same 1990 model I pulled dash from. ![]() G*d I don't remember what all else I've done to this thing, but it's been a lot. I drive it daily now for my job search. Still to do is to replace the vacuum seals around the injectors, #2 is leaking pretty bad and the idle surges +\- 300 rpms, probably from when I replaced the injectors to fix hesitation. If s*it were to hit the fan on this project, and I were in need of a new motor, then I'd highly consider dropping in a 602 and mate it to my 5spd getrag. |
