Mercedes E 300 TDT - Printable Version
+--- Thread: Mercedes E 300 TDT (/showthread.php?tid=4894)
Mercedes E 300 TDT - Ksteen2 - 09-12-2013
hi again,
I got my 3rd car running ;p
not a big thread, my new daily, because the W123 has been too
tunned to be used on the road :p
the W124 has a
it's a OM603.912, with mounted turbo from a Tahoe 6,5td
and a manuel tranny swap
and a home made 7mm 120cc pump, so the first test run
killed my driveshaft ;o
pic's will come tonight or tomorrow Wink
RE: Mercedes E 300 TDT - 1911diesel - 09-12-2013
nice, im interested in the diy 7mm elements. and are you saying your using a chevy 6.5 turbo on your om603? how is that working out for you? how much boost will it run? when does boost kick in? im putting a 6.5 turbo on a 6.2 in a week or two for a buddy. and i know the guy that owned the 6.5 turbo and until he tied the waste gate closed he said it was pretty much useless...lol
RE: Mercedes E 300 TDT - Jetmugg - 09-12-2013
Is this a W124 wagon? TDT?
A later model (post '90) W124 diesel wagon with a 5-speed would be super-cool.
Steve.
RE: Mercedes E 300 TDT - Ksteen2 - 09-13-2013
Bought the elements from germany and mounted them in the pump in norway, sendt them to a shop that have a test bench and they adjusted it.
its a W124 wagon a S124 with a om 603, 91mod, with a 5 speed manuell Wink
yes, its a turbo from a 6.5td
it work werry well with the 7mm elements, with totaly shut wastegate it starts to build presure ar 1700-2000 rpm's, and full boost att 2800-3000 rpm's Smile
RE: Mercedes E 300 TDT - Ksteen2 - 09-16-2013
Hey !
so, in the weekend we had a gathering, It's called street meet.
when 60-100 people with a car enthusiasm meet's up,
talks car's and whatever and laugh'n have fun Wink
this was held att a location in Hamar.
some pics of my daily driver:
[Image: mercedes300td_zpsa0ce5983.jpg]
[Image: mercedes300td1_zps5fa4c6ff.jpg]
[Image: mercedes300td2_zps58853279.jpg]
Only stock Turbo diesel exhaust, so, much black smoke ;o
but i have build a 3" now Wink
anyone know hos much a stock 300D block can handle?
not org turbo, just aftermount Wink
more photos Wink
[Image: mercedes300td4_zpsa3831ed8.jpg]
[Image: mercedes300td3_zpsa74bd6ec.jpg]
RE: Mercedes E 300 TDT - 1911diesel - 09-16-2013
i dunno how much a stock block can take, but be sure to push the limits and let us know! back when i was a mini trucker we had a saying, build it to break it, then build it stronger. i think the same applies here. good luck and delete the road. or track.
yeah, It's my daily, so i don't want it to break :p
it handle's 2 bar pretty good, so I was thinking to drive it att 1.4-1.5 or somthing :p
RE: Mercedes E 300 TDT - mantahead - 09-16-2013
looks like fun, keep her smoking.Tongue
RE: Mercedes E 300 TDT - Tito - 09-16-2013
I'm currently building a n/a om603 with holset hx35w and 7mm diy pump. I'm thinking of running 1.4/1.5 bar boost also. I let you know how it turns out. I don't expect major problems. Yeah, there's no piston sprayers but i'm not going to go flat out all the time. And keep a good eye on my egt.
RE: Mercedes E 300 TDT - Ksteen2 - 09-17-2013
in this pictuers I had 1,8 in boost, and have been over 2 bar.
and my chevy turbo is about the same size ass you'r 35 Wink
RE: Mercedes E 300 TDT - Tito - 09-17-2013
Did you do anything special to the pump? I fitted the 7mm elements en than brought it to a Bosch shop for calibrating. (Also 120cc I believe, it's was 2 years ago) and turned the full load screw 2 turn ccw.
Good job. I love a black station wagon :-D
RE: Mercedes E 300 TDT - HaavardPYA - 09-17-2013
Tou need to buy some stiffer springsWink
no, not really, just took of the rail travel screw, and there we go Wink
yes haavard Wink
i need, but first i need to get ridd of the crapy original high adjustment in the back :p
RE: Mercedes E 300 TDT - Tovikblacksmoke - 09-22-2013
hello Smile i from noeway to and just bought a 300tdtWink where did u buy your element? 7mm? right? and where in our homecontry is a dieselworkshop, who can calibrate it? How mutch hp with 7mm element and tahoe 6.5 turbo? And what kind of turbo is it on tahoe ? Big Grin
RE: Mercedes E 300 TDT - Ksteen2 - 09-23-2013
hello Wink
the elements ar 7mm from dieselkontor.de
a man Named Thorbjørn vardeberg did it for me, the most of Fyksen shop's can calibrate it Wink
with the K26-K27 borg warner from the Tahoe I think it makes about 200-250hp att 1,8bar boost, but not dyno'd
you can run a 10-12cm hx35 or hx40 with a TDT and those elements and around 2 bar boost as long as it is a stock turbo engine, I think you should have around 300-350 with the 120cc the 7mm puts out, with stock rack travel etc..
nice to so many norwegians on this forum Wink
RE: Mercedes E 300 TDT - Tovikblacksmoke - 09-24-2013
Oh.. nice! Se on your page i sended you a PM Wink
On your 7mm element, have you turned the feedscrew all the way out? you have M-Pump?
RE: Mercedes E 300 TDT - Ksteen2 - 09-25-2013
(09-24-2013, 07:23 PM)Tovikblacksmoke Oh.. nice! Se on your page i sended you a PM Wink
M-pump on all OM60x in europe..
i don't know what the have adjusted it to ;p
I just know it is 120cc :p
RE: Mercedes E 300 TDT - Tovikblacksmoke - 09-25-2013
(09-25-2013, 06:21 AM)Ksteen2
oh.. smood!Big Grin So you have no more diesel to give on your pump ?
RE: Mercedes E 300 TDT - Ksteen2 - 09-26-2013
I don't think so :p
it's more then I will use on this car anyway :p
RE: Mercedes E 300 TDT - Tovikblacksmoke - 09-26-2013
(09-26-2013, 02:13 AM)Ksteen2 I don't think so :p
Cool Big Grin som pic of the engine? ^^
RE: Mercedes E 300 TDT - Ksteen2 - 09-27-2013
yeah, can take a few Wink
RE: Mercedes E 300 TDT - Ksteen2 - 11-14-2013
so now, my S124 is traded for a S123 !
i love the 123 chassis Big Grin
RE: Mercedes E 300 TDT - Tovikblacksmoke - 11-14-2013
hmm.. intresting!
RE: Mercedes E 300 TDT - Ksteen2 - 11-15-2013
here is the new wagon!
[Image: 1453363_447938685325795_1392137675_n_zpseed11c81.jpg]
RE: Mercedes E 300 TDT - willbhere4u - 11-15-2013
You lucky bastard.
RE: Mercedes E 300 TDT - Ksteen2 - 11-18-2013
I know, now I own a W123 with OM606.962 and a S123 with a OM617.962 :p
it's to great cars Big Grin
RE: Mercedes E 300 TDT - w123love - 11-19-2013
You’ve got to ship those body kits over here! So cool!
RE: Mercedes E 300 TDT - Ksteen2 - 11-19-2013
its a cut of W210 front bumper and custom made side skirts from W210 asvell :p
RE: Mercedes E 300 TDT - Tovikblacksmoke - 11-20-2013
Whats the plan for the s123? Wink
RE: Mercedes E 300 TDT - Ksteen2 - 11-21-2013
nothing for the moment :p
but maybe it will get a little bit bigger turbo and a DIY pump sometime.
RE: Mercedes E 300 TDT - mike-81-240d - 11-22-2013
Do you have a better pic of the w210 bumper thing? looks pretty cool.
RE: Mercedes E 300 TDT - Ksteen2 - 11-22-2013
no, not now, but I can tr to take one Wink
RE: Mercedes E 300 TDT - Ksteen2 - 04-05-2014
I got the hang of a another S123, the old is gone, I bought this, had an original 617.962, with about 100.000km on the engine.
I put a 110cc diy pump and a BW K27 from mercedes atego.
it did push good on boost, for two weeks, then the engine sat hard, was'nt gonna move.
of to engine swap
[Image: 22EEFDE1-29CC-4D69-B9E2-112C1714E815_zpsic5sj1xb.jpg]
put in a little bit better enginge in my taste !
a OM603.962.
it will gett a diy pump on about 120cc and the BW K27 that i hat on the 617 Wink
[Image: FDA72D49-4596-4699-B444-3A72DA9FA791_zpsxfhqbrrd.jpg]
