240D won't start - Printable Version
+--- Thread: 240D won't start (/showthread.php?tid=49)
240D won't start - EuroDriver - 10-06-2008
It will run for a few seconds when I prime the pump but then dies. Would this be the injection pump crapped out or could it just be a clogged filter? Haven't had a chance to mess with it too much(too much overtime). Hopefully someone will tell me good news.
Re: 240D won't start - winmutt - 10-06-2008
EuroDriver It will run for a few seconds when I prime the pump but then dies. Would this be the injection pump crapped out or could it just be a clogged filter? Haven't had a chance to mess with it too much(too much overtime). Hopefully someone will tell me good news.
Easiest check is get a empty bottle fill it with fuel and hook the in and out fuel lines into it and try to start the car. Could be clogged filter, clogged tank screen bad fuel. Many other things.
Re: 240D won't start - ForcedInduction - 10-07-2008
Did you change the filter?
