OM606 engine problem bad sound - Printable Version
+--- Thread: OM606 engine problem bad sound (/showthread.php?tid=4954)
OM606 engine problem bad sound - olefejer - 09-27-2013
Bad sound, it sounds like a injector sticking, but it is not as the sound do not go away, when i loosen one by one injector pipe ?
And the sound is there and then suddenly not and the again ?
Mae by a sticking hydraulic valve actuator ?
Anyone had the same problem ?
http://www.youtube.com/watch?v=k7zGr2b3xUI&feature=em-upload_owner#action=share
Ole
RE: OM606 engine problem bad sound - Simpler=Better - 09-27-2013
I'm not an expert but it sounds similar to my friend's VW2.0 petrol that has a stuck lifter
RE: OM606 engine problem bad sound - hansendk - 09-27-2013
Hi Ole
what is the km on the engine and do you know the history on the engine
is it worse in the morning after standing still the whole night thats normaly the way and bad lifter is spotted
to check take the rocker cover off and try to press on the lifter with a big screw driver but only on the valves that closed then turn the engine until you have checked all, if they are faulty you will be able to press them down so there is a gap between the cam and the lifter thats whats make the noise.
if you need new ones dont buy in Denmark thats to expensive buy on ebay UK or Germany
jeg kunne jo havde skrevet det paa dansk men saa var der jo ikke mange der forstaar det.
mvh. Ib.
RE: OM606 engine problem bad sound - Tito - 09-28-2013
That's not a lifter. The sound is too rough. Leaky lifters make the same noise over and over. Looks like it's rattling at crankshaft speed.
RE: OM606 engine problem bad sound - olefejer - 09-28-2013
(09-27-2013, 11:00 PM)hansendk Hi Ole
mvh. Ib.
The history on the engine is 160000 width 100% service history when i bougt, it then 130,000 as suber turbo in my car total 290,000
That should be nothing.
Tak Ib :-)
RE: OM606 engine problem bad sound - Volker407 - 09-28-2013
What happens with the noise at medium or high rpm? (another Video?)
Did you check compression already?
Gruß
Volker
(09-28-2013, 12:22 AM)Tito That's not a lifter. The sound is too rough. Leaky lifters make the same noise over and over. Looks like it's rattling at crankshaft speed.
Hi
Yes you are right it sound nasty, i would say you are right, if it was not that the sound go away now and then, but i will found out tomorrow.
Then i test injectors and valve lifters.
Ole
(09-28-2013, 03:25 AM)Volker407 What happens with the noise at medium or high rpm? (another Video?)
Gruß
Volker
Higher RPM = louder and more consistent.
No had not checked compression. NO TOOL :-(
Gruß
Volker
Higher RPM
http://youtu.be/8A9ooQkr1Go
And now it does not go away anymore, well valve cover goes off tomorrow.
My guess would be pump timing has gone too early on one or several cylinders.
You could turn the injection pump as late as possible and see if it gets better or worse.
Gruß
Volker
RE: OM606 engine problem bad sound - INC - 09-28-2013
It`s sad to say, but seems You have to remove oil pann, and check big end bearings Sad
RE: OM606 engine problem bad sound - olefejer - 09-29-2013
(09-28-2013, 01:22 PM)INC It`s sad to say, but seems You have to remove oil pann, and check big end bearings Sad
I Was lucky it was just 2 pcs of sticking injecktor, it was not closed that meant it was injecting much to early giving this bad sound,
http://youtu.be/mnVxB2d-jN8
I put injector in from other spare engine, now runs absolutely fine.
One injector was really bad and the other was a little bad, but enogth to still have a little bad sound when i was loosen the injector pipe to locate the problem
SmileSmileSmileSmileSmile
RE: OM606 engine problem bad sound - INC - 09-29-2013
(09-29-2013, 12:13 PM)olefejer
Nice to hear that problem is gone so easy.
Bad fuel?
Sound was not so nice.
RE: OM606 engine problem bad sound - Duncansport - 09-29-2013
Lucky, my engine made a clatter clatter sound for about 100ft the stopped dead two weeks ago.... Totally lock up now:-(
