Must have this tool! - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Open (https://www.superturbodiesel.com/std/forumdisplay.php?fid=13) +--- Thread: Must have this tool! (/showthread.php?tid=5032) |
Must have this tool! - winmutt - 10-18-2013 Kobalt LED Lighted Socket Wrench Ratchet Handle 1 4" Drive 72 Point 5 Degree Arc | eBay MUST! (well the 3/8 and 1/2 versions) RE: Must have this tool! - willbhere4u - 10-18-2013 For a second there I thought it was both 1/4 and 3/8 on the back but that's just the switch for the light oh well RE: Must have this tool! - JB3 - 10-18-2013 I'm gonna be captain buzzkill ![]() I got all excited about it too, but then it occured to me that 90% of the time I use my ratchet, I have a solid extension on it, so the light in the ratchet would be useless. Plus when you have an extension, you are way more likely to be working wih something hard to see, vs right near the ratchet with just a socket being something usually pretty easy to see if you have that much room. So you have light when you generally least need it. Therefore ill hold off until they make a lighted 6 inch extension instead. I see really limited utility to this thing. (10-18-2013, 10:04 PM)JB3 I'm gonna be captain buzzkill EDIT- I take it back, ebay listing shows lighted extensions! Cool RE: Must have this tool! - winmutt - 10-21-2013 Yes they make the extensions as well!! RE: Must have this tool! - willbhere4u - 10-21-2013 I just want a double sided ratchet 1/4 and 3/8 all in one RE: Must have this tool! - MFSuper90 - 10-21-2013 (10-21-2013, 03:51 PM)willbhere4u I just want a double sided ratchet 1/4 and 3/8 all in one Pretty sure I've seen one before, not sure where tho RE: Must have this tool! - EDH_Performance - 10-23-2013 (10-21-2013, 05:00 PM)MFSuper90(10-21-2013, 03:51 PM)willbhere4u I just want a double sided ratchet 1/4 and 3/8 all in one I have a set with that kind of ratchet ![]() |
