Anybody else hate Chrysler products? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Open (https://www.superturbodiesel.com/std/forumdisplay.php?fid=13) +--- Thread: Anybody else hate Chrysler products? (/showthread.php?tid=5078) |
Anybody else hate Chrysler products? - sassparilla_kid - 11-07-2013 Because I sure as hell do now. My dad's '01 Ram 1500 in addition to needing new heads, crank position sensor, and paint, now needs a new throwout bearing, which means probably everything clutch related at the same time. And I'm sure if I thought about it for a while I could think of some other things wrong with it Oh yeah the dash exploded one day while driving, and the several hundred pieces are now held together with duct tape. Oh yeah and half of the front bumper fell off one day for no apparent reason RE: Anybody else hate Chrysler products? - willbhere4u - 11-07-2013 I like the 5.9 cummins but its a million mile motor in a 100k mile truck vs fords 1 million mile truck with the 100k mile power joke I would still take either over a Chevy any day of the week RE: Anybody else hate Chrysler products? - Simpler=Better - 11-07-2013 Fullsize-get a Chevy but not the ones that require you to pull the hubs for a brake job. The new(2011) Silverado is a dream to work on I can sit in the engine bay. Fords are nice too, except for the damn F150 has the engine half under the dash and is a bitch to work on. Plastic intake manifold? Yeah that's a good idea.... Chrysler gets really close but then the cost accounting kills them. Wifey's I6-awesome engine, one year they decided to lightweight the head. Bam, cracks on ALL 2001 I6 heads at around 90k. 4wd with solid axles, NP transfer case, 4link, awesome!! But let's put a stamped steel dana35 rear axle that bends when you look at it. We need better emissions! Add an egr? Reprogram the ecu? Maybe a new cam design? Spec a 210°F thermostat to keep it hot hot hot....aaaand... let's stuff 2 cats literally 4 inches under the intake manifold and then add 5 heat shields to keep from setting the fuel rail on fire. Modern car that gets vapor locked on hot days. GJ Chrysler. MMMM big SUV=under hood space? Let's tuck the steering box, radiator, trans cooler together with 1/2" clearance for wrenches. now there's plenty of visual space under the hood! If they had moved the radiator over 2", or just put the lower hose on the passenger side this would not be an issue. Electric fan? Great! I won't overheat while spinning 3,500rpm in 4 low while wheeling. Let's put a cheapo under-rated relay BETWEEN THE HEADLIGHT AND FENDER LINER SO IT OVERHEATS AND FAILS. While we're at it, don't change the fan shroud-we can't afford new molds so just leave the extra 5" of plastic to get in the way while doing the water pump for a 1" thick electric fan. But then the good stuff...easy good cheap brakes, reusable trans pan gaskets, 4link suspension front & rear, easy dash to disassemble for radio/heated seat stuff, super easy headlight/tail light maintenance, oil changes are a dream-no jacks required even with stock wheels/suspension. I love the Jeep, it's a great ride and has plenty of powah, but some things really piss me off while working on it. RE: Anybody else hate Chrysler products? - sassparilla_kid - 11-07-2013 Yeah this truck is the 3.9 V6, which sucks, because for all the 8- cylinder models you can get beefier Mopar performance heads that don't crack, but not the stupid 6-cylinder RE: Anybody else hate Chrysler products? - Simpler=Better - 11-07-2013 (11-07-2013, 04:08 PM)sassparilla_kid Yeah this truck is the 3.9 V6, which sucks, because for all the 8- cylinder models you can get beefier Mopar performance heads that don't crack, but not the stupid 6-cylinder 4.0L I6 2003-2004 would be the easiest swap RE: Anybody else hate Chrysler products? - sassparilla_kid - 11-07-2013 Would it bolt right up or what? Also I suspect it wouldn't just be plug and play with all the electronics and mating them up to the computer in the car RE: Anybody else hate Chrysler products? - Simpler=Better - 11-07-2013 6 cyl, 6 cyl....the trans and motor mounts would be the determining factor. RE: Anybody else hate Chrysler products? - MFSuper90 - 11-08-2013 He'll with it, put a cummins in it RE: Anybody else hate Chrysler products? - willbhere4u - 11-08-2013 4bt would be just about perfect it's also a 3.9 RE: Anybody else hate Chrysler products? - sassparilla_kid - 11-08-2013 If I could find one from a vehicle newer than the truck I would in a heartbeat because it would be legal in California RE: Anybody else hate Chrysler products? - Simpler=Better - 11-08-2013 Seriously research the 4.0L. It's no race motor, but it moves the Heep around just fine. It's got to be better than the crappy v6 (no offense) RE: Anybody else hate Chrysler products? - sassparilla_kid - 11-08-2013 I hate the v6, and I'm totally down for an engine swap in this beast, but due to CARB regulations engine swaps in California are only legal on smog exempt vehicles (pre-74 or 76 or something) or the engine has to be swapped in from a newer model vehicle with all of its emissions components. RE: Anybody else hate Chrysler products? - Simpler=Better - 11-08-2013 (11-08-2013, 01:23 PM)sassparilla_kid I hate the v6, and I'm totally down for an engine swap in this beast, but due to CARB regulations engine swaps in California are only legal on smog exempt vehicles (pre-74 or 76 or something) or the engine has to be swapped in from a newer model vehicle with all of its emissions components. They used the I6 on 2004 Chrystlers...does that count? RE: Anybody else hate Chrysler products? - sassparilla_kid - 11-08-2013 Yeah it just has to be newer. I should just find a newer diesel and put in it, it needs more diesel |
