om602 - Printable Version
+--- Thread: om602 (/showthread.php?tid=5214)
om602 - llt6000 - 12-26-2013
hi
i have a w201 2.5D without turbo
and i would like very mutch to strap a turbo on too it
so what do i have too do with the diesel pump
my goal is only about 150-160 hp
do i have to get bigger elements or is there antoher option?
RE: om602 - Duncansport - 12-26-2013
http://www.superturbodiesel.com/std/Thread-1991-300D--4514
RE: om602 - orion - 12-27-2013
Primarily you need an other engine. The 602 without turbo has other pistons, valves and the oil reservoir is larger than yours. Further the IP has an ALDA.
RE: om602 - llt6000 - 12-27-2013
okay thanks but if i then go for the om605 engine can i use the pump from my om602?
RE: om602 - Duncansport - 12-27-2013
(12-27-2013, 05:12 PM)llt6000 okay thanks but if i then go for the om605 engine can i use the pump from my om602?
Sure can, direct bolt on. Most parts will swap over from the 602 to the 605. EPC even shows a lot of 602 parts make up the 605..
