NEED (123) alternator Housing... ALL SET, THANKS - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: NEED (123) alternator Housing... ALL SET, THANKS (/showthread.php?tid=5263) |
NEED (123) alternator Housing... ALL SET, THANKS - OM616 - 01-16-2014 Hi everyone.. My alternator gave out and the housing is cracked, so I need a rebuildable core to have rebuilt. A good empty housing would be fine too. The car is a 84 300D (123) with a 617a Mine has a two belt pulley.. I have had such bad luck with chain store rebuilds that I will not do another one. Just my luck that mine has a bad housing.. RE: NEED (123) 300D ALTERNATOR HOUSING!! - Simpler=Better - 01-16-2014 ALX129 was only $120 last I checked, could be time for an upgrade? RE: NEED (123) 300D ALTERNATOR HOUSING!! - OM616 - 01-16-2014 (01-16-2014, 03:37 PM)Simpler=Better ALX129 was only $120 last I checked, could be time for an upgrade? I’m not familiar with that part number.. I assume it is a higher out put? The stock one puts out enough power.. When it is working I should say lol.. RE: NEED (123) 300D ALTERNATOR HOUSING!! - capflya - 01-16-2014 It's a 115a alt if I remember correctly. I think I have an alternator at home, it might even be good. I'll look when I get home and let you know. RE: NEED (123) 300D ALTERNATOR HOUSING!! - Simpler=Better - 01-16-2014 I ran one in my 300D, you need to make up battery cables. If you're cheap you can mod the stock one. Last I knew advance auto had 2ga for stupid cheap, like $25 for 50ft when you bought the whole roll. http://www.ebay.com/sch/i.html?clk_rvr_id=574363520060&_nkw=al129x&rt=nc&LH_PrefLoc=1 http://www.peachparts.com/shopforum/diesel-discussion/93569-alternator-115-amp-bosch-al129x-works-123s.html You may or may not need to clock the housing to get past an AC hose, and the pulley may or may not need to be swapped. RE: NEED (123) 300D ALTERNATOR HOUSING!! - capflya - 01-17-2014 I do have an alternator. It was a bosch reman, even says mercedes on it. Has a little noise when I spin in but it could just be because it sat for a while. If you want it let me know and we can work something out. RE: NEED (123) 300D ALTERNATOR HOUSING!! - OM616 - 01-18-2014 All set.. Many thanks to everyone who responded.. |
