Wrecked a tranny!! and changed to tough one - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Wrecked a tranny!! and changed to tough one (/showthread.php?tid=5270) |
Wrecked a tranny!! and changed to tough one - pmj4147 - 01-18-2014 (Before the start the thread, Sorry for my bad English) Hi guys!! Finally i wrecked a stock(Borg-warner) tranny!!! 60,000km with 6mm pump, 5000km more with 7.5mm Turbo is still a garrett stock. just 1.4bars of boost. I was cruising on outside circle road with 5th, 2300rpm Down shifted to 3rd gear, engaged the clutch and crushed. whatever...... Ssangyong used 3 kind of Manual tranny, mine was SMF borg-warner. the first one the second one is Borg-warner DMF type the third one is 'Hyundai WIA' made DMFtype tranny (all 3 are compatible with OM60*, M10* motors) The third one is wat i choose. it's a stock tranny too. But extremely enhanced durability for high-torque and it's targeting about 500hp. it's a typical RR type gearbox. and i think i can ship it from here if who needed http://www.hyundai-wia.com/download/automotive.pdf Click the link and find a A100 model. Catalog says 170hp holding But it's just a stock engine power RE: Wrecked a tranny!! and changed to tough one - F.R.A.S - 01-18-2014 What about this one? M6VR2 looks like a strong one on paper. Does it fit the Mercedes engine? That gearbox came in the Hyundai Genesis Coupé 3.8 v6 model according to Mr. Google. RE: Wrecked a tranny!! and changed to tough one - pmj4147 - 01-18-2014 (01-18-2014, 10:25 AM)F.R.A.S What about this one? M6VR2 looks like a strong one on paper. Does it fit the Mercedes engine? It's for a Hyundai GENISIS Coupe 2.0, 3.8 gasoline engine. as you know i don't think it'll fit to om60* Maybe customize the bell housing ![]() RE: Wrecked a tranny!! and changed to tough one - F.R.A.S - 01-18-2014 How expensive are those gearboxes where you live? (01-18-2014, 10:55 AM)pmj4147 It's for a Hyundai GENISIS Coupe 2.0, 3.8 gasoline engine. as you know RE: Wrecked a tranny!! and changed to tough one - bigbortha - 02-04-2014 Are the ssangyong om602 gearboxes suitable for power increases? i am aiming to install an om605 on to a Pajero mk2 and would like to go with a bolt on gearbox instead of an adapter plate and custom flywheel. Thanks RE: Wrecked a tranny!! and changed to tough one - pmj4147 - 02-09-2014 (02-04-2014, 04:20 PM)bigbortha Are the ssangyong om602 gearboxes suitable for power increases? Sorry for late answer. Yeah it's suitable for a bit about 7mm pump?? i used about 200,000km with 6mm pump RE: Wrecked a tranny!! and changed to tough one - bigbortha - 02-10-2014 thanks for the reply so it can take a bit of abuse then RE: Wrecked a tranny!! and changed to tough one - pmj4147 - 02-11-2014 (02-10-2014, 03:33 PM)bigbortha thanks for the reply It can take some of that But if you can find 2005MY Musso sports, Use that tranny would be way better than standard Borg-Warner RE: Wrecked a tranny!! and changed to tough one - bigbortha - 02-11-2014 thanks for the info i will keep my eyes open |
