Om662 la what power is possible - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Om662 la what power is possible (/showthread.php?tid=5359) |
Om662 la what power is possible - Stevo-trendy - 02-19-2014 Hi everyone first proper post since my introduction anyway I'm thinking of buying a w201 2.5 non turbo with a manual box soon as a project i wish to drop the musso 2.9 turbo engine into it as a simple power plant as I know I won't be able to live with the non turbo plodder . My question is after I have dropped it in what sort of engine mods could I do to be making around 200-250bhp ? How tuneable is the 662la engine ? Has anyone on here messed around with one or the fuel pump & different turbos ? A problem I will bump into tho when I fit the 662la is that the turbo with hit the steering box as the uk market never got the turbo om602's as there rhd & the steering box is in the way . How have people sorted this problem out ? Many thanks Steve RE: Om662 la what power is possible - pmj4147 - 02-24-2014 (02-19-2014, 12:07 PM)Stevo-trendy Hi everyone first proper post since my introduction anyway I'm thinking of buying a w201 2.5 non turbo with a manual box soon as a project i wish to drop the musso 2.9 turbo engine into it as a simple power plant as I know I won't be able to live with the non turbo plodder . My question is after I have dropped it in what sort of engine mods could I do to be making around 200-250bhp ? How tuneable is the 662la engine ? Has anyone on here messed around with one or the fuel pump & different turbos ? Hi There is a two types of 662LA 120PS stock, 132PS stock. Second one is a better one actually Thicker con-rod, Thicker piston, More efficient coolant line in cyl head, etc so, it can handle over 250hp for sure, 300 could be ok But there's a low rev limit because 602, 662 2.9 has too long stroke than other standard OM engines RE: Om662 la what power is possible - mario - 02-24-2014 I fitted an om605 with turbo into a right hand drive w124 with no issues. Power steering pipes are thight but dont seem to foul and the exhaust pipe is off a standard w202 c class. RE: Om662 la what power is possible - Stevo-trendy - 02-24-2014 Hi There is a two types of 662LA 120PS stock, 132PS stock. Second one is a better one actually Thicker con-rod, Thicker piston, More efficient coolant line in cyl head, etc so, it can handle over 250hp for sure, 300 could be ok But there's a low rev limit because 602, 662 2.9 has too long stroke than other standard OM engines [/quote] Is there a way to tell between each om662 la engine ? I'm thinking of buying a whole damaged jeep for the engine either rexton , musso or korando & break the rest for spares , have you got a build thread or could you pm me pictures if your build if you have any many thanks |
