om605 intake manifold - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: om605 intake manifold (/showthread.php?tid=5363) |
om605 intake manifold - F.R.A.S - 02-20-2014 Ok guys, due to a lot of questions about manifolds, both intake and exhaust I'm willing to share our 605-build. As you can see the manifold is ready as far as welding and fabrication. Now we gonna blaster it and paint it so it gets a nice even surface. And yea, the cones are all the way through. The cones are cnc-machined! Even inside the manifold there are some bits and tricks, but some of that is secret so I have no good photos of the fabrication RE: om605 intake manifold - CRD4x4 - 02-20-2014 I like the cone baffles! Nice work! Did you source them from another application or are they custom made? RE: om605 intake manifold - Hario' - 02-20-2014 Very impressive! Can I ask is that a NA 606 manifold with one runner cut off? I thought no 605 manifolds were aluminium? (I want one) Regards, H. RE: om605 intake manifold - F.R.A.S - 02-20-2014 Thanks. They are custom made by our local machine shop. (02-20-2014, 05:00 PM)CRD4x4 I like the cone baffles! Nice work! Did you source them from another application or are they custom made? It's from a om606 right, turbo or not I do not remember. But yea, just a runner cut off. Just send me a message and I'll hook you up with one (02-20-2014, 05:07 PM)Hario Very impressive! RE: om605 intake manifold - Eric78 - 02-21-2014 I've never seen anything like that before, what do the cone baffles do? I've an OM605 which I plan to use a air to water intercooler on & was planning that the intercooler be welded to the runners to form the plenum but looking at that I might mount the cooler indendent of the manifold & run a plenum instead. RE: om605 intake manifold - erling66 - 02-21-2014 Strange looking manifold To make those cones and put them there is a lot of work so I guess you have a good reason to do that and I guess you have a flow bench and have come up with that solution after a lot of testing? Maybe you have some more info you would like to share with us RE: om605 intake manifold - F.R.A.S - 02-21-2014 The cone baffles are there to make the plenum stiff. Usually you just use pipes, but this looks better. So it's more or less a design feature. (02-21-2014, 02:52 AM)Eric78 I've never seen anything like that before, what do the cone baffles do? There are some secrets inside the plenum (02-21-2014, 03:12 AM)erling66 Strange looking manifold To make those cones and put them there is a lot of work so I guess you have a good reason to do that and I guess you have a flow bench and have come up with that solution after a lot of testing? Maybe you have some more info you would like to share with us RE: om605 intake manifold - willbhere4u - 02-21-2014 ready for some massive boost then because of the cones RE: om605 intake manifold - F.R.A.S - 02-21-2014 3.5bars (51psi) to start with Aiming for 700hp in this one. But we'll have a twisting road ahead... We have a Dieselmeken Crazy Jim Edition IP 242cc 7250rpm limiter. But we're planing of four to five big upgrades before we reach maximum power with good durability. (02-21-2014, 12:59 PM)willbhere4u ready for some massive boost then because of the cones RE: om605 intake manifold - willbhere4u - 02-21-2014 please post some video when its running RE: om605 intake manifold - F.R.A.S - 02-21-2014 It's a while till it's done, but yea, I'll post some videos when it runs. (02-21-2014, 03:09 PM)willbhere4u please post some video when its running RE: om605 intake manifold - Stamsaas - 02-22-2014 How much would you take to make a custom good-flowing om605 intake manifold? Norway needs one RE: om605 intake manifold - F.R.A.S - 02-22-2014 Anything for our brothers in the north west. Send me a message and we'll take it from there. (02-22-2014, 05:44 AM)Stamsaas How much would you take to make a custom good-flowing om605 intake manifold? Norway needs one |
