K26 Turbo Upgrade for the OM617 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: K26 Turbo Upgrade for the OM617 (/showthread.php?tid=5391) |
K26 Turbo Upgrade for the OM617 - snowbrd84 - 03-03-2014 I put an OM617.951 in my 89 Jeep Wrangler and it has the Garret stock turbo in it. With 0psi boost at idle, it is a dog off the line until about 10mph when boost kicks in and the motor starts to rev and it takes off like a rocket ship. From what I have read, the K26 turbo produces about 2psi at idle and provides much better acceleration. Anyone have any experience with this upgrade? Will any K26 bolt on, or just one off of an OM617? Anyone have one they would like to sell at a decent price? I would go to the u pull it, but dont have much time with work these days. For background, ALDA is removed, manual boost controller delivering 15 psi max, ive got an EGT, boost gauge, etc... Ive done the valves, put in new monark nozzles, diesel purge, everything... RE: K26 Turbo Upgrade for the OM617 - lgreeley83 - 03-03-2014 I have one I pulled off mine I'll have to check shaft play. My guess is it is not top notch. 2 psi at idle noo. I never saw its performance on a "stock" car. Mine had wide open 3",exhaust and fuel pump modified in some way by prior owner. My testimony would not apply to stock. I swapped a garret onto it (60trim mod) and I didn't really notice a difference in initial boost. People say kkk26,spools quicker but I don't know. Oh and a direct swap it is. RE: K26 Turbo Upgrade for the OM617 - snowbrd84 - 03-03-2014 (03-03-2014, 02:17 PM)lgreeley83 I have one I pulled off mine I'll have to check shaft play. My guess is it is not top notch. PM me with how much you want for it, shipped to 20814. Thanks. RE: K26 Turbo Upgrade for the OM617 - MFSuper90 - 03-04-2014 2psi at idle would be supercharger status. And if was building that much boost at idle, it would grenade from spinning too fast on too end unless the waste gate was enormous RE: K26 Turbo Upgrade for the OM617 - snowbrd84 - 03-04-2014 (03-04-2014, 09:47 AM)MFSuper90 2psi at idle would be supercharger status. And if was building that much boost at idle, it would grenade from spinning too fast on too end unless the waste gate was enormous Yeah but I did read it on the internet, so it must be true right? Thanks for debunking the bad info, but I think the general consensus is that the K26 does build boost earlier than the Garrett right? RE: K26 Turbo Upgrade for the OM617 - raysorenson - 03-04-2014 Yes, that the consensus. There are plenty of options to get an even more responsive turbo than the kkk on the t3 flange and since your setup doesn't need a lot of boost, the options are even greater. RE: K26 Turbo Upgrade for the OM617 - willbhere4u - 03-04-2014 Maybe 2 psi by 2,000 rpm instead of by 2,500 rpm the Garrett dose it in RE: K26 Turbo Upgrade for the OM617 - cho - 03-05-2014 (03-04-2014, 12:48 PM)raysorenson Yes, that the consensus. There are plenty of options to get an even more responsive turbo than the kkk on the t3 flange and since your setup doesn't need a lot of boost, the options are even greater. which one (or two) would you suggest mate? thanks . RE: K26 Turbo Upgrade for the OM617 - snowbrd84 - 03-05-2014 (03-05-2014, 06:56 AM)cho(03-04-2014, 12:48 PM)raysorenson Yes, that the consensus. There are plenty of options to get an even more responsive turbo than the kkk on the t3 flange and since your setup doesn't need a lot of boost, the options are even greater. Yeah come on man, thats just mean to lead in with there is a much better option and then not tell us what that option is. Any suggestions are much appreciated. Thanks. RE: K26 Turbo Upgrade for the OM617 - raysorenson - 03-05-2014 There's like a billion turbos out there, depends on what you're looking for. If it were my '89 jeep, I'd try to find a turbo that's more flexible than the 2 old-tech O.E. options. Flow just as much on the compressor side or maybe a tad more, but less inertia and faster spooling. For a stock pump that's been turned up, maybe a gt25r? It should live a long time on 12 psi. Not sure if you can get one in a t3 flange but adapters are all over. Or how about a VNT? GT2559v. Turbo lag sucks on a 4x4. RE: K26 Turbo Upgrade for the OM617 - Simpler=Better - 03-05-2014 Variable vane is the route you want to go. You will probably spend $100-$150 on pods to regulate it but the instant boost is incredible. Over in the engine sticky the pattern for a 2056v (aka M53 from CRD liberty jeeps) is up there. 2056v is a bit small, the 2256v is closer. Neither is good for high HP numbers, but both spool fast. RE: K26 Turbo Upgrade for the OM617 - sassparilla_kid - 03-05-2014 Sounds like you need to turn up the pump a little ![]() RE: K26 Turbo Upgrade for the OM617 - snowbrd84 - 03-05-2014 (03-05-2014, 12:41 PM)Simpler=Better Variable vane is the route you want to go. You will probably spend $100-$150 on pods to regulate it but the instant boost is incredible. Pods to regulate? The whole reason I havent been considering a VNT is because everything I see says you have to come up with a way to control it. RE: K26 Turbo Upgrade for the OM617 - sassparilla_kid - 03-05-2014 There's a guy on here in the bay area I believe who came up with a pretty simple way using the throttle and vacuum or something, I'll see if I can find it. Or I've seen big holset turbos have the controller taken off and replaced with a coil spring, when the back pressure gets too high the vanes start to open http://www.superturbodiesel.com/std/Thread-Syncro-s-mechanical-VNT-project Or this https://www.youtube.com/watch?v=iiDAB2bB7t8&feature=youtube_gdata_player RE: K26 Turbo Upgrade for the OM617 - MFSuper90 - 03-08-2014 An hx25 would be super fast spool, if your not too worried about top end. Maybe even a hy30 or a small s200 Borg Warner model. The biggest problem with those is the exhaust manifold would have to be adapted to the smaller t25 inlet or whatever it is. Oh and as far as a variable charger goes, their a fellow on 4btswaps that makes controllers to control the vanes on the turbos. Kinda pricey, but they have aweskme options and he will custom tune it to your likings RE: K26 Turbo Upgrade for the OM617 - carlitosgy6 - 03-08-2014 i have both turbos,i was using the garret stock turbo and the lag was too much,if i had to take off on a hill then i had to slip the clutch a lot just to see no boost,the kkk26 is the one i have now and is a lot better at takeoff but still laggy and restrictive at the top end, if you don't care having lots of power at high speed and prefer low end and faster spooling get the kkk26,if not modify your garret or put a better one on its place,i was thinking doing a biturbo setup,2 stage but at low boost because i want 5 psi at take off and high speed performance RE: K26 Turbo Upgrade for the OM617 - Alcaid - 03-09-2014 (03-08-2014, 12:35 AM)MFSuper90 An hx25 would be super fast spool, if your not too worried about top end. Maybe even a hy30 or a small s200 Borg Warner model. Holset HE211W will spool even faster than HX25 as turbine wheel is smaller and only 5cm turbine housing. T25 flange on that one as well RE: K26 Turbo Upgrade for the OM617 - snowbrd84 - 03-10-2014 (03-09-2014, 05:03 AM)Alcaid(03-08-2014, 12:35 AM)MFSuper90 An hx25 would be super fast spool, if your not too worried about top end. Maybe even a hy30 or a small s200 Borg Warner model. Million dollar question is, is there a good source to find these turbos? The go to ebay/craigslist yields nothing... I might try a holset, if i can find one... RE: K26 Turbo Upgrade for the OM617 - Alcaid - 03-10-2014 (03-10-2014, 09:42 AM)snowbrd84 Million dollar question is, is there a good source to find these turbos? The go to ebay/craigslist yields nothing... I might try a holset, if i can find one... Your looking at a source ![]() I can get a HE211W drop shipped to you from Holset factory for 625$ (including my PayPal fees) if interested. These are brand new and genuine turbos ![]() Do I get a million dollar for answering your question? ![]() RE: K26 Turbo Upgrade for the OM617 - snowbrd84 - 03-10-2014 (03-10-2014, 10:08 AM)Alcaid(03-10-2014, 09:42 AM)snowbrd84 Million dollar question is, is there a good source to find these turbos? The go to ebay/craigslist yields nothing... I might try a holset, if i can find one... haha, I probably should have been a little clearer in the question. Between student loans, rent, bills, etc, $625 is not doable... That sounds like a perfectly acceptable price for a brand new, from the factory, part. But my budget is more towards the used and in good condition and sitting on someones shelf that has no use for it. There is no way I could spend more than $200, I dont even know how its going to work out... I am going to try the K26 first, and just keep on the lookout for a used holset... RE: K26 Turbo Upgrade for the OM617 - MFSuper90 - 03-10-2014 (03-10-2014, 10:19 AM)snowbrd84(03-10-2014, 10:08 AM)Alcaid(03-10-2014, 09:42 AM)snowbrd84 Million dollar question is, is there a good source to find these turbos? The go to ebay/craigslist yields nothing... I might try a holset, if i can find one... Alcaid has some of the best holset prices I have ever seen ![]() And snowbird, it is very, very unlikely you will find a used holset for $200. If you do, it will probably need at least a $50 rebuild. And that's if your lucky enough to get one that doesn't have crazy wear and need to be machined for under/oversized bearings. I would just save your money and wait to buy a new one ![]() RE: K26 Turbo Upgrade for the OM617 - sassparilla_kid - 03-10-2014 Iheartboost has a Holset 351 for sale, but I think that's a little big without a superpump RE: K26 Turbo Upgrade for the OM617 - atypicalguy - 09-16-2014 (03-08-2014, 12:35 AM)MFSuper90 An hx25 would be super fast spool, if your not too worried about top end. Maybe even a hy30 or a small s200 Borg Warner model. Who is that guy? Contact info? Thanks. Edit Nevermind i found it http://www.4btswaps.com/forum/showthread.php?29441-Universal-HE351VE-Controller RE: K26 Turbo Upgrade for the OM617 - atypicalguy - 05-13-2015 Is anyone here actually driving with a 5cm exhaust housing on their turbo? |
